History Help. ID 1940 (?) 6 volt clock
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, May 22, 2024.
  1. Ebbsspeed
    Ebbsspeed
    I picked this up yesterday from the swap table at our weekly Model A meeting. Can anybody identify it? Manufacture date stamp appears to be November 1940, so likely from a 1941 model. Built by Jaeger Watch Co in NY.
    EDIT: The dimensions of the hole it would fit in would be 2" high by 2.75" wide. The mounting hole spacing is 3.25" center to center.
    I cleaned and lubed it, and now it runs like a clock. It's an interesting movement. Not the typical set of points that close every few minutes to energize a solenoid to stretch a spring. This one has a pin on the balance wheel that brushes up against a spring contact each time it rotates back and forth, which provides a momentary ground that energizes an electromagnet and pulls the balance wheel in the opposite direction.
    FYI, the black background behind the numbers was some version of purple or burgundy when I got it. I painted it black.
  2. BJR
    BJR
    Is there a question there somewhere, or are you just showing us your new clock?
    Bob Lowry likes this.
  3. gary macdonald
    gary macdonald
    What are the measurements? It may fit in my 41 , not correct but better than an empty hole . That is if it’s for sale.
  4. Ebbsspeed
    Ebbsspeed
    The question is in my original post, asking if anyone could identify it. I have no idea what make or model it is from.
  5. Ebbsspeed
    Ebbsspeed
    It would need a hole 2" high by 2.75" wide. Distance between the mounting holes is 3.25" Not for sale at this time as I may use it in my old Buick.
    I added the dimensions to my original post. Thanks.
    gary macdonald likes this.
  6. gary macdonald
    gary macdonald
    Thank you and good luck .
  7. Bandit Billy
    Bandit Billy
    10 to 1 it's a mopar. Get it...10 to 1. 12:50. Never mind.
    lowrd, Tim and Bob Lowry like this.
  8. rustydusty
    rustydusty
    I’ve got an extra glove box door for my ‘40 Olds with a clock in it. I will check it out tomorrow…
  9. Ebbsspeed
    Ebbsspeed
  10. Ebbsspeed
    Ebbsspeed
    1940 Olds was one of my suspects, but they have the time setting knob on the front. This one has it on the back.
