Hot Rods Help ID 409 distributor
Discussion in 'The Hokey Ass Message Board' started by Youngster51, Aug 19, 2022.
  1. Youngster51
    Youngster51
    from Fresno ca.
    Picked up this 409 today and this distributor was on it and can’t find any info or photos of it?
  2. squirrel
    big truck governor type?
    jaracer and Bob Lowry like this.
  3. Mike VV
    Mike VV
    from SoCal
    Or industrial ?
    I've has several, none looked like that !
    Mike
  4. squirrel
    Did it have an aluminum band just above the collar that is used to clamp it in place in the engine? If so, that band would have the part number, mfg date, etc stamped on it. Very useful info.
    427 sleeper likes this.
  5. 427 sleeper
    427 sleeper
    Definately not a p***enger car application. 40 series or bigger truck or industrial application possibly.
  6. Youngster51
    Youngster51
    from Fresno ca.
    It did not have the band on it. The engine has a factory dual quad setup and has the 3814690 Hipo heads
  7. Youngster51
    Youngster51
    from Fresno ca.
    I read about a special ordered transistorized ignition system that was available for the 409 could this be the distributor for that setup? Said it took a special magnetic field distributor.
  8. 427 sleeper
    427 sleeper
    Can you give us the numbers off of the front of the block? Maybe someone for some reason thought it would be a good idea to put a 425hp top end on a low compression grain truck motor. :confused:
    joel, Youngster51 and squirrel like this.
  9. 427 sleeper
    427 sleeper
    That distributor looks pretty much like a regular distributor, except the points and condenser were replaced with the transistorized pieces.
    Youngster51 likes this.
  10. squirrel
  11. Youngster51
    Youngster51
    from Fresno ca.
    Yea it’s definitely that big truck distributor. That’s a weird setup to run
  12. squirrel
    I don't see any electronics on it, and there's only one wire, can we see inside the thing where the points are? another picture perhaps?
    The Chevy truck parts book lists one distributor for trucks from 58-64 with the 348 or 409, part number 1112767, googling that number finds nothing.
    The vacuum line and air filter can and internal valve are related to the governor used on the big truck engines, there's also a vacuum diaphragm on the carb.
  13. Mr48chev
    Well, I'm going to have to say that some guy found it in a mid 60's truck and stuck it in his car and stuck the dual quad setup on it and didn't get the distributor or make any other changes. Pretty much the same as when you see an unmodified tall deck 427 in a car now days. My buddy was a big block freak for years and had at least one kid who had stuck a tall deck in his Chevy show up at his place asking why his aluminum high rise wouldn't bolt up on his engine. Kid had the car running and driving governor and all as he had put it back together when he couldn't get the intake to fit.
  14. vtwhead
    vtwhead
    Could it just be a 409 truck block. I have seen lots of 348's in trucks but have never come across a 409. What are the numbers on the front tab of the block? Dip stick on the p***enger side?
  15. vtwhead
    vtwhead
  16. Youngster51
    Youngster51
    from Fresno ca.
    The suffix code is **G so truck or replacement block. All the top end stuff is high horse 409.
  17. Youngster51
    Youngster51
    from Fresno ca.
  18. squirrel
    neat! is there a casting date code on the back of the block somewhere? Might also be above the oil pan rail.
  19. vtwhead
    vtwhead
    That is a late 64 or 65 block used in both car and truck. In trucks it may have cylinder relief cuts to reduce the compression. **G was only used as a replacement for trucks.
    What is the head casting number? 690's or did you really get lucky with a set of 583's used with the Z11 high lift cam:rolleyes:
    Oops! I see you said 690's. Quite a find for certain. I think I have a distributor out of a 409 in the shop that needs a good home. PM me if interested.
    squirrel and rusty valley like this.
  20. stillrunners
    stillrunners
    from dallas
    Truck 409's are the new hi-po 409's now......maybe someone was on the cutting edge ? Sadly they use to just s**** those 409 truck motors.......
  21. L5wolvesf
    L5wolvesf
    I know this thread is nearly a year old but I came across it while looking up the distributor I have. It looks to be pretty complete so I figured I would put a couple pics as the OP had requested. But . . .
    I don't know how to post a pic here from my laptop.
  22. squirrel
    there should be a ****on below the place where you type in the text, that says "upload a file". You click that, then upload the image file (which is what we call a picture on a computer).
    If you have trouble, keep asking, we'll get it figured out.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    here is the tutorial for posting pictures. It is super easy
    https://www.jalopyjournal.com/forum/threads/how-to-post-images-on-a-thread.922350/
  24. L5wolvesf
    L5wolvesf
    OK here are the pics
  25. L5wolvesf
    L5wolvesf
    Thanks guys. That was simple. Maybe I am too :)
    Budget36 and Moriarity like this.
  26. squirrel
    you could even clean off the aluminum band on the distributor, and put the numbers here for us to see. Then we could look it up and know for sure that it's a medium duty truck W motor distributor
    Moriarity likes this.
  27. L5wolvesf
    L5wolvesf
    It is a 1112767. That's how I came across this thread.
  28. vtwhead
    vtwhead
  29. squirrel
    the 1969 Chevy truck parts book shows 1112767 to fit All 348-409 from 58-64 (first design).
    So it's a truck distributor. Like I thought.
