I am not seeing much on these, I just found it and would like to know where it has been. it is a Borg Warner T86E-1A 3spd Od trans, Has H15C-2 stamped on machined surface on top, right rear tab by cover, If someone out ther can tell me what make model year or direct me towards a place wher I can find out, I'd buy 'em a cold frosty if they came around my neck of the woods! thanks, matt
The only thing that I know off that used super long input shaft like that was IHCs. What is the diameter of the input splines that might give a clue. Also Packard maybe.
It may have come out of a Jeep with that long input shaft. Either way, you are missing the OD solenoid. Good Luck
