Technical Help ID another engine.
Discussion in 'The Hokey Ass Message Board' started by ziegld1, Sep 18, 2015.
  1. ziegld1
    ziegld1
    from St Louis
    Everyone, Thank you for the help and tips from the past. I have another engine that I need help on an ID. It is a four-cylinder engine, the head cover is only 11-inches so it's small engine. I believe it could be a Austin engine used in Reliants. I also think they were modified for racing in the 600-750 cc cl***es. Any thoughts, comments, etc. appreciared.
  2. Cute little thing, whatever it is.
  3. slowmotion
    slowmotion
    Don't know **** about 'em, but I'll throw Crosley out there just for the heck of it.:D
  4. Fortunateson
    Fortunateson
    Grandfather to Chevy's Mouse engine; 1924 Gerbil!?
    Texas Webb likes this.
  5. Dick Stevens
    Dick Stevens
  6. chriseakin
    chriseakin
    Maybe it's a Cooper (oops Coventry) Climax used by Cooper? I've never seen one but they started off as power plants for firef fighting water pumps and were quite compact. Don't remember Austin ever making an OHC which is what that looks like.
  7. gimpyshotrods
    gimpyshotrods
    Hey @RichFox, does this engine ring a bell with you?
  8. RichFox
    RichFox
    I know for sure it's not a Coventry Climax. Or Crosley. Other than that. No. Reliant comes to mind. But I don't know.
    volvobrynk likes this.
  9. The37Kid
    The37Kid
    Nice find! Post that question and photo over on PreWarCar.com someone over there will know. Add to to the "Lets Talk Cyclecars" thread here on the HAMB as well. Bob
  10. 56sedandelivery
    56sedandelivery
    Stutz ***** Cat? Prerunner to the Stutz Bear Cat. I am Butch/56sedandelivery.
  11. gimpyshotrods
    gimpyshotrods
    Curious through-block fixture. Must be a mount, as I cannot see any other way to put mounts on it.
  12. The37Kid
    The37Kid
    Not all the way through, there is crankshaft in there. I'd like to know why there is a break in the case of emergency window in the cam drive tower. Bob
    RICH B and volvobrynk like this.
  13. Rusty O'Toole
    Rusty O'Toole
    I'm guessing it is some sort of industrial power plant never meant to be used in a vehicle. It has that look. The flywheel seems to have no provision for a clutch.
  14. Katuna
    Katuna
    from Clovis,Ca.
    Looks like it would make a *****in go-kart engine. Cute little thing.
  15. gimpyshotrods
    gimpyshotrods
    I blew up the picture. It shows 9 holes, to hold a pressure plate.
  16. chessterd5
    chessterd5
    from u.s.a.
    Is that a fuel pump boss on the side of the cam cover at the top? It looks like it's not milled out?
  17. The37Kid
    The37Kid
    I think so, that is a camshaft powered generator mount in front. Bob
  18. partsdawg
    partsdawg
    from Minnesota
  19. RichFox
    RichFox
    I was thinking that the distributor would mount there on the front of the cam
  20. Ebbsspeed
    Ebbsspeed
    Pretty sure Rich is correct in that is where the distributor would mount.
  21. volvobrynk
    volvobrynk
    from Denmark
    More pics of the gearbox might give a hint of its last purpose in life.
    Maybe industrial or forklift.
  22. landseaandair
    landseaandair
    from phoenix
    Very little in the way of accessories. Could be Magneto and gravity fed updraft but no water pump? Wonder if it was a stationary starter motor but seems a little overbuilt with an overhead cam. Got to be some kind of markings somewhere. Whats it look like under valve cover? Bolts metric or SAE?
