Technical Help ID Edmunds intake
Discussion in 'Traditional Hot Rods' started by rhughes78, Aug 14, 2021.
  1. rhughes78
    rhughes78
    I picked up an intake from a friend who has his own personal junkyard. He said last time he counted there were over 500 cars across 20 acres.... Anyway, I got this intake from him and thought it would look neat to hang in the shop. I asked him what it came off of and he has no clue, other than it’s been in the junk yard for at least 50 years. I can’t seem to find any information on it. It says Edmunds customs on it and is 2x2 carbs. I found one identical to it on eBay that lists it as a flathead Cadillac. But the crossover for the thermostat on the front makes me think otherwise. Any information would be helpful.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    303 324 Oldsmobile, If you clean the bottom, they are usually stamped with what it fits. I have a 2x4 edmunds that is stamped 53 Olds on the bottom
    warbird1 and Deuces like this.
  3. Ebbsspeed
    Ebbsspeed
    I can confirm that it IS NOT from a flathead Cadillac.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    it is 303 324 Olds
    Deuces likes this.
  5. 302GMC
    302GMC
    from Idaho
    Note the w i d e spacing so 2 of the Rochester "AA" backdraft carbs would fit ....
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    here is the ID stamping on the bottom of mine
    Deuces and Desoto291Hemi like this.
  7. tubman
    tubman
    Since it is an Olds, aren't there a couple of versions, large port and small port)? I think that may be the small port version for the earlier 303's. I'm no expert, but when I bought intake gaskets for my '51, I seem to remember that there were 2 or 3 choices, depending on port size.
    Deuces likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    it looks like 303 ports to me, he needs to clean the bottom and look for the stamping
    Deuces likes this.
  9. vtwhead
    vtwhead
    Tubman, there was an early version that I believe had an open web design with smaller ports like this: this: [​IMG]
    Deuces and 302GMC like this.
  10. jimmy six
    jimmy six
    I’ll bet if Mr Hughes cleaned it up first he may not have needed to ask. But then again to a certain group of enthusiasts all the s**t on it that some think is the “P” word would want it that way..
    302GMC, warbird1 and Moriarity like this.
  11. 302GMC
    302GMC
    from Idaho
    Used to bead blast all the used stuff I found. Now, I only clean it if I'm going to use it immediately.
    Deuces and jimmy six like this.
