Technical Help ID emergency Parking brake handle.
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jan 1, 2026.
  1. bustingear
    bustingear
    braket5.jpg braket4.jpg braket3.jpg braket2.jpg braket1.jpg Help ID emergency Parking brake handle. Cant quite figure this one. Can you help with year range and model? Thanks!
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I used a similar one on my champ car build for the rear brake handle. This gave me two braking options - a 4-wheel hydraulic brake system for the street and a two-wheel rear mechanical brake for the track.
    I asked the same question about its origin and folks identified it as a '41 Chevy truck.
    No?
    brake 01.JPG brake 02.JPG brake 21.JPG brake 22.JPG brake 27.JPG brake 40.JPG
    I must say, I thought it was a rather elegant looking piece and fit the vibe of my car perfectly.
  3. bustingear
    bustingear
    thanks any other feed back on this?
  4. squirrel
    is there a part number on it?
    and can you make the pictures full size so we can see them all without having to click them?
    sure looks like the Chevy lever he pictured, with a different bottom.
  5. alchemy
    alchemy
    I’ve got a very similar lever packed away that I was told originated on a 28 Chevy.
  6. gimpyshotrods
    gimpyshotrods
    Chevy truck. I just made one into a shifter for a customer.
    It will have a 7-digit number on it.
  7. bustingear
    bustingear
    what years on the chevy truck?
  8. squirrel
    30s-60s? :)
    gimpyshotrods likes this.
  9. Bob Lowry
    Bob Lowry
    Ebay shows one to be for a '40 to '46 Chevy truck...
  10. bustingear
    bustingear
    Thanks there are a couple on ebay however if you look closely the base area is quite different.
  11. squirrel
    it's probably pretty old then, the later ones were used only on the SM420 transmission, which has the base that you see most often.
    Perhaps late 20s-mid 30s cars?
  12. tb33anda3rd
    tb33anda3rd
    looks identical to the one on my 39 GMC truck
  13. willys36
    willys36
    It is definitely 30's vintage GM. Had a '36 Pontiac with a similar one. Don't remember what the ratchet end looked like. My guess is that is the feature that will differ between makes.
