History Help ID Ford 3-window coupe
Discussion in 'The Hokey Ass Message Board' started by Delco115, May 5, 2026.
  1. Delco115
    Delco115
    Guys and gals..... Not sure where to post this, so it can be moved if needed. I've looked and looked but cannot determine the year of this coupe. All I have is this old picture of my Mom and Dad next to it. My thought is this was taken in late Sept of 1949 just after they were married. Any help will be greatly appreciated, and my thanks goes to all that may have the answer.
    210superair and CSPIDY like this.
  2. dlw1932
    dlw1932
    from Nebraska
    Looks to be a 41-48 Ford coupe. Not a 3 window. It would be a 5 window, they are just standing/blocking the B-Pillar.
    49ratfink, porkshop and squirrel like this.
  3. squirrel
    this is a 41, but they looked pretty similar to 46-48. Fender trim, standard/deluxe, etc. It's a business coupe, eh?
    49ratfink and porkshop like this.
  4. 1946caddy
    1946caddy
    from washington
    1941 Ford
    Just Gary and 49ratfink like this.
  5. Delco115
    Delco115
    My thanks to you guys. I should have thought far enough ahead to realize it had a 'B' pillar behind them. DOH!!
  6. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Delcoll5, was your dad in the 5th BG by chance? If I remember right that is their patch.
    Mike
    Outback and porkshop like this.
  7. ronzmtrwrx
    ronzmtrwrx
    If I recall correctly, some folks also called that a “short door” coupe, and the regular coupe with a back seat a “long door”.
    Just Gary and catdad49 like this.
  8. Delco115
    Delco115
    Mike....I tried sending you a private conversation, but couldn't figure out how to send it after I typed it. Regardless, here's an original version of the patch as was on his uniform. Thanks for noticing and commenting on it. Chuck
    hrm2k, Just Gary, 49ratfink and 7 others like this.
  9. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Aircrew Staff Sgt., cool! I even love the patch on his IKE jacket patch, I have never seen that before. Do you mind if I use this picture on the Jungle Air Force FB page? My grandfather was a Crew Chief in the 394th BS/5BG. Do you know what plane he flew on?
    Also, if you click on my name, find the 'start a conversation' and the PM will pop up.
    Mike
    Okie Pete and Outback like this.
  10. mgtstumpy
    mgtstumpy
  11. J.D.
    J.D.
    from Clovis, CA
    Zooming in on the picture the beltline trim doesn't look like it has the ribs that the 41 Fords do. Could be a 41 Mercury as they had smooth trim that had a similar width as the ribbed Ford trim.
    It almost looks like the rear quarter trim is wider than the door/cowl trim. Rear quarter looks like 47/48 smooth trim and door/cowl looks like 41 Mercury smooth trim.
    Long Doors are also called Sedan Coupes
  12. 42merc
    42merc
    '41 Ford, no rear fender shields & exposed running board edges.
  13. 5window
    5window
    Damn we sent kids off to war
  14. Ford made two different coupe bodies '41-'48. One that used the same doors as a 2 door sedan, one that used the same doors as the front doors on a 4 door sedan.
