Help ID Nailhead
Discussion in 'The Hokey Ass Message Board' started by mercjoe, Sep 9, 2008.
  1. mercjoe
    mercjoe
    Guys,
    Apparently 54' with its factory 3 speed. Forget about the fan :)
    Anybody can tell whether its a 264 or a 322 ?
    Is it worth to get one of this earlier and smaller nailheads ? are performance parts available ?
    Asking $500
    Thanks
    Diego
  2. FoMoCoPower
    FoMoCoPower
    No,this is a Nail Head............
  3. btbsandman
    btbsandman
    try www.v8buick.com those guys there can direct you better than I can.
    i have a baby nailhead, the v6 from 1962, and i can still get a performance cam and headers for it.
  4. striper
    striper
    That looks like a red X to me.
    Casting numbers on a 54 264 3 sp block are 1391871. On a 54 322 look for 1391753.
    Pete
  5. Detonator
    Detonator
    from santa cruz
    I have a '54 322 in my rpu. I've been looking at your pix and walking back and forth into the shop to compare. The heads and valley pan look pretty much identical. Those early valve covers you have look to be in great shape. The ones with the embossed shield are gettin' hard to find -- one of the Buick re-pop companies still makes the color stickers that go onto these shields, if you're into a resto-look. (If you're not, sell 'em to me!)
  6. tstellhorn
    tstellhorn
  7. arkiehotrods
    arkiehotrods
    The 264 was offered only in the Special, so if the body is not a Special, it's likely you have the 322.
  8. mercjoe
    mercjoe
    Mh, I guess its a 264 in the end :(
    good thing is the manual ****** is there. Are those
    good transmissions ?
    I do like the looks of a nailhead for sure but is it worth to build such a small
    cid engine ?
    Anyone running one of this ??
    Thanks guys
    D.
  9. mercjoe
    mercjoe
    Thanks.
    I still dont own it. Im looking to buying it for myself. Im far away from you, dont think you're gonna like shipment costs ;)
  10. zman
    zman
    from Garner, NC
    264's and 322's are the baby nailheads. What you have is a V6. :eek:
    It's actually the baby brother of the 215 Aluminum V8...
    If the distributor is in the front it's not a Nailhead... :)
  11. belair
    belair
    322 has a real harmonic balancer, 264 just has pullys bolted to front of crank. If it's a 264, the trans has, to quote Brad 54 (I think) "gears made of gl***". There is a heavier duty 3-speed, has 6 bolts instead of 5, (I think), they are hard to find. Also, I have heard it is next to impossible to find a cluth for a 264. Maybe a Nailhead guy will chime in. I have one, with a WONDERFUL tri-duece 322 I might let go, but...... Also, try the search. Not many new questions on the HAMB.
  12. panheadguy
    panheadguy
    from S.E. WI
    Yeah, a V6. Maybe there's only two cyls on the opposite bank
  13. mercjoe
    mercjoe
    Is not a V6 man and 264s and 322s are V8 engines.
    Just by looking at the valve covers you can tell its a nailhead. I have no doubts about that, I was trying to figure out which one.
    Thanks for all the help huys.
  14. mercjoe
    mercjoe
    Ok, I can see this engine will do no good.
  15. zman
    zman
    from Garner, NC
    Maybe you should go back and read my reply... I replied to
    btbsandman calling his V6 a baby nailhead.
    And no, just looking at the valve covers will not tell you it's a Nailhead. 215's and 300's had the horizontal valve covers as well. Is the distributor in the back? That and the horizontal valve covers will ID it as a Nailhead the easiest.
    Jeez....
  16. mercjoe
    mercjoe
    You are right, sorry Zman
    D.
  17. Flat Roy
    Flat Roy
    It,s hard to tell from the pic,s but all of the afore mentioned details plus it looks like a big rochester 2 barrel on it also hints that it is a 264.
  18. tstellhorn
    tstellhorn
    I'm building up a 264 engine right now. If the engine is big enough depends on what you want to do with the car and the size (weight) of the car it's pushing. I'm NOT planning on taking my car to the drag races, but I'm sure the engine will have enough power to get the car around the block &#8211; and the scratch the tires every so often! Again, I think it all depends on what you want to do with the car and how much horsepower you want/need.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p></o:p>
    On the topic of finding a 264 manual clutch - Yeah, they are hard to find. Just as hard to find is the 264 flywheel which is NOT interchangeable with the 322, as most parts are between the two engines. The 264 flywheel is balanced differently than the 322 flywheel. According to email exchanges I&#8217;ve had with Russ Martin (http://www.nailheadbuick.com/) a 322 flywheel on a 264 engine will shake the 264 apart. For my configuration, I've got a stock 264 clutch, but I'm planning to run a more modern Chevy clutch bolted to my stock flywheel. The 264 flywheel bolt patterns match up to a Chevy clutch. <o:p></o:p>
    <o:p> </o:p>
    Also &#8211; As general information &#8211; Clutch Masters (http://www.clutchmasters.com/) in <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:eek:ffice:smarttags" /><st1:place w:st="on"><st1:City w:st="on">Rialto</st1:City>, <st1:State w:st="on">CA</st1:State></st1:place> is the place to go. They machined my 264 flywheel for $23 while I waited. They also have a HUGE inventory of new and used clutches. Clutches is pretty much all they do.
    <o:p> </o:p>
    Todd
  19. TagMan
    TagMan
    "According to email exchanges I&#8217;ve had with Russ Martin (http://www.nailheadbuick.com/) a 322 flywheel on a 264 engine will shake the 264 apart. For my configuration, I've got a stock 264 clutch, but I'm planning to run a more modern Chevy clutch bolted to my stock flywheel. The 264 flywheel bolt patterns match up to a Chevy clutch."
    Russ is exactly correct on that. I had a 264 in my '55 Special that was slipping real bad. I tore it apart and had it rebuilt by a clutch rebuilder in town and it slipped just as bad afterwards. I then did a little digging and found out the pressure plate was pretty weak, even for a little motor like the 264. I bolted a Chevy pressure plate to the original Buick flywheel and it worked great until I yanked it and installed the 401, but that's another story.....
