History Help ID Quickchange rear end
Discussion in 'Traditional Hot Rods' started by Youngster51, Dec 9, 2019.
  1. Youngster51
    Youngster51
    from Fresno ca.
    Hi I purchased a T Roadster earlier this year and after finding old pictures of the car and learning history on it I’m pretty sure it raced sometime in the 40’s in the Bay Area or northern California but I can not find anything on the rear end. The case has LOW in raised letters on the sides and the cover. I went to rebuild the brakes and after removing the lug nuts to get the wheel off the axle slid out of the rear end there is no clips or retainers holding it in the only thing is the lug nuts with a plate that is sandwiched between the drum and a floating hub which I think might be magnesium. I think the axle bells are 1932 And has 40 Ford drums and backing plates any help on this rear end is appreciated thanks here is some pictures
    2D6CBCF4-223C-4571-B3F2-4C8EB4773DB2.jpeg 64793DDA-6753-450F-B357-624B650C3B21.jpeg E25AFBF8-3EED-4712-B4ED-36857C8A670C.jpeg B2BEE8D2-A90A-42FF-A0B9-F6B1A054EB32.jpeg 82AF04BA-A320-44D9-8979-664090A7966E.jpeg 95D38CEE-C6FF-4A9D-9131-5994098B302F.jpeg DF33C3FC-C6A8-4982-BAEB-10FFE28A0177.jpeg 2BCB9FD9-4E0B-48E0-8EEE-F38F01FB0480.jpeg 39157C40-9F52-4986-B76B-ED9918DD7B7F.jpeg EA8D0EA8-D0F2-4CB5-86A1-9DC8AE170BEC.jpeg A2B8FEE9-9E84-46E6-A51C-63121CDB2949.jpeg 5E906C27-06CC-4181-A22D-F6CA5368B4F6.jpeg EB859D4C-F072-4407-96FF-1D5ABEF10FF2.jpeg 6887B0A9-FE30-40B0-BF42-5AC28D562BFE.jpeg 9291F4B4-6382-46A6-A6F1-4A0D45955937.jpeg
    kidcampbell71 and tractorguy like this.
  2. alchemy
    alchemy
    The drums are 40, the brakes are 48, the housings are kinda looking like Model A to me, but maybe unsupported pinion 32. The wishbones are 36. The hub and axle setup is really cool, probably one of a kind now.
    tractorguy, Tim and kidcampbell71 like this.
  3. Interesting to say the least. The housings look model A to me also, looks like the spring mount tabs have been cut off in picture below.
    How are the hubs held on? Are there a large nut(s) under all that grease?
    Or are the hubs held on with the 4 bolts that hold the backing plates on?
    kidcampbell71 likes this.
  4. The backing plates look 40ish. Looks like the bolts pattern on the axle housing may have been filed out to make the backing plates attached. Notice how the washer and bolts seem to favor the outside of the housing bosses.
    By money is on , that the hubs are held on by the 4 bolts. Kinda make this a full floating axle ***embly. The Hub carries the weight of the car, the axles slide in and provide power transfer.
  5. Youngster51
    Youngster51
    from Fresno ca.
    under the grease in the pictures is Just bearing the hub spins on I think the hubs are pressed onto a snout and the snout is bolted to the 4 bolts for the backing plate
  6. Marty Strode
    Marty Strode
    Quite a find, is the center section cast iron/steel ? Geared pretty high, around 2.65 if the ring and pinion is a 3.78, perhaps it was raced at the lakes or Bonneville.
    tractorguy likes this.
  7. kidcampbell71 likes this.
  8. What does the spline look like on the removable axles?
  9. Youngster51
    Youngster51
    from Fresno ca.
  10. Youngster51
    Youngster51
    from Fresno ca.
    Here is a few pictures
  11. Someone sure did a lot of custom work on that axle, very impressive work considering the time period.
    Axle shafts are keyed on one end and splined the other. Ford hubs have been shortened at the axle nut. Wonder what they used inside to allow splined axles? I wonder what carrier they used or how highly modified the carrier was modified to accept the splined spider gears.
    kidcampbell71 and Youngster51 like this.
  12. What bolt pattern on the wheels, looks like 4 3/4" or 5"
  13. Youngster51
    Youngster51
    from Fresno ca.
    do you think with all the custom work and machining that the case could be homemade also that’s why I’m not finding any info on the Low case
  14. Youngster51
    Youngster51
    from Fresno ca.
    In the late 50’s it was changed from race car to show car sometime between the late 50’s and the mid 60’s it was drilled to 5 x 4 3/4 Chevy pattern the other pattern is 5x5.5
  15. alchemy
    alchemy
    The backing plates are 42-48 (See the little bumps around the outer edge that the shoes ride on? That's the easy giveaway.). They bolt right on all rear axle housings from 28-48, no hole mods needed.
    Youngster51 likes this.
  16. No, I have seen reference to LOW Engineering before, just escaping me right now.
  17. Youngster51
    Youngster51
    from Fresno ca.
    i put a magnet on it it’s either magnesium or aluminum
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Edit: I mistakenly creidted the LOW information to Craigibc it was actually from @zieglsd1.
    I found a reference to a LOW Quickchange. Was sent to me by Dave Ziegler. He has not been on here since 2017.
    Here is what he sent me:
    LOW
    San Leandro, CA.
    Len Low
    Was made in the early to mid 50’s. After a few years Len moved from California to Nevada, This quick change was used of a Hisso 4xd midget.
    Yours it the first one I have ever seen,
    Bruce
  19. Youngster51
    Youngster51
    from Fresno ca.
    that would make sense I bought the car in Oakland Ca. Right next to San Leandro ca. The ch***is picture I posted is when the owner bought it in the late 50’s and dis***embled it and built it into a show car you can see in the picture it had a flathead mid plate center steering and the same quick change it was changed over to SBC and a 4 speed out of a vette the car also came with a radical built 37 flathead with Eddie Meyer speed equipment that I was told it raced with
  20. Youngster51
    Youngster51
    from Fresno ca.
    have you seen the work on the axles and hubs have you seen that before on other quick changes? Do you think you could tell if it was set up for round track racing or dry lakes it would give me an idea of where to look for old race photos to try and find race history on the T roadster thank you
  21. rusty valley
    rusty valley
    no pics of the whole car?
  22. Marty Strode
    Marty Strode
    If you post pics of the whole car, I will search my photo collection on Track Roadsters .
  23. Youngster51
    Youngster51
    from Fresno ca.
  24. Youngster51
    Youngster51
    from Fresno ca.
    here is some current photos and old show photos of the car at Oakland roadster show I’m trying to find old race photos or race history on it it has a moly tube ch***is is what the show card says it runs friction shocks on all 4 corners the early ch***is picture shows it having center cowl steering flathead mid plate with inside wheel discs 40 Ford wheels juice brakes it’s a steel 1922 T roadster body has been customized the Firewall and cowl has been shifted to the left to Keep the steering arm inside the cowl the turtle deck has lowered and molded the door was molded
  25. stillrunners
    stillrunners
    from dallas
  26. seb fontana
    seb fontana
    from ct
    The change gears seem to be of finer pitch than normal [current] gears?
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I thought that too, Seb.
  28. Youngster51
    Youngster51
    from Fresno ca.
    Would it be tough to find gears to change out the ratio?
  29. Marty Strode
    Marty Strode
    It's standard 6 spline stuff, slide one of them off and check the width, V-8 will be 1.375 thick, Model A and Midget will be thinner.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    ^^^^^^^^^Unless they didn't use the standard 3" Center to Center spacing!
    seb fontana likes this.
