Technical HELP ID sbc heads and work to install roller rockers
Discussion in 'The Hokey Ass Message Board' started by 1955 F-100 guy, Apr 15, 2023.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Went to put new valve covers on and SURPRISED to find roller rocker heads-- here are numbers to help ID heads-- Thanks
  2. TCTND
    TCTND
    The rockers are aftermarket; there were no "roller rocker heads".
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    Mid 70's smog heads. Google that casting number for lot's-o-info.
    Deuces and Johnny Gee like this.
  4. Bob Lowry
    Bob Lowry
    From another post
    Deuces and Lloyd's paint & glass like this.
  5. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    So if these are stock heads how much work had to be done to install these roller rockers would this mean the engine might have a ROLLER cam in it instead of a old style flat tappet cam-- Thanks
  6. Lloyd's paint & glass
    They just bolt on. The heads still have the press in studs, so I wouldn't think that whoever built it went too exotic on the cam, but you never know!
  7. 19Eddy30
    19Eddy30
    from VA
    Like others have said ,
    Pretty much Stock set up (springs) with bolt on rockers
    & looks to have aftermarket push rods
    ( drop in )
    No guide plates , If you have a good eye
    or bore scope ,pull a push rod look down in side down towards lifter & see if you see a crossbar for roller lifters
  8. gary macdonald
    gary macdonald
    Stock mid 70s low compression, pressed in studs , all said before.
    If it was my truck , Id change the rubber fuel line , especially where pinched by the lower alt mount
    Truckdoctor Andy likes this.
  9. Dooley
    Dooley
    from Buffalo NY
    Large chambers but decent flowing heads.
    The rockers are just bolt on not full roller as was said.
    If you need higher compression ratio for your cam then you can switch to 64 Cc heads but otherwise they are decent
  10. 1971BB427
    1971BB427
    from Oregon
    These are really not great heads with open chambers, and not large runners. Roller rockers just bolt on, but these heads have press in studs still, so definitely wont take much cam lift. They're also known to develop cracks, so keep an eye on the breathers for signs of water getting into the oil if they do crack.
  11. s55mercury66
    s55mercury66
    from SW Wyoming
    They are the better, heavier smogger casting, I think that changed around the same time Chevrolet Orange went away.
