Technical Help ID these brake rotors
Discussion in 'The Hokey Ass Message Board' started by 63401nailhead, Sep 17, 2023.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    Is there a good reason not to get them machined on a brake lathe?
    X38 likes this.
  2. Beanscoot
    Beanscoot
    It's more money, but I like to reface rotors on a flywheel grinder. You can grind only the required amount on each side independently, and it provides an original finish.
  3. 63401nailhead
    63401nailhead
    from Oregon
    I called about a half dozen places this morning, nobody within 20 miles will turn rotors anymore. I found a place that very reluctantly said they can do it for $200, I told them the rotors are already off the truck, but she said she can’t change that in the system.
    So if I can’t replace them, then yes I will have them turned
  4. chickenridgerods
    chickenridgerods
    from DSM, IA
    Did you check with your local NAPA, Car Quest, or O'Reilly?
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I'd want to know what they are...period. There can be only so many choices for these rotors. If it were me...:rolleyes: I'd take one with me to an 'old school' auto parts place, set it on the counter, then go through the process of elimination. I've done this very thing many times and had things eventually work out. Just recently went through this on a trans tail housing bushing and seal.
    You just need to find a good parts place that's managed by car guys. Car guys help each other out...right? Good luck!
  6. alchemy
    alchemy
    But, I would be doing the what-is-its with the old school shop guys while the rotors were on their brake lathe.
    X38 and SR100 like this.
  7. lostviking
    lostviking
    I looked up disk brake conversion for 1940 Chevy Truck and got a number of hits. Some have brackets that look a lot like yours. The point is they all are about the same thickness, and all their rotors need to fit on your spindle. Worth asking for a part number I think.
  8. 63401nailhead
    63401nailhead
    from Oregon
    I was able to get the rotors turned, cost $80 to do them both.
    I took the numbers off the old bearings:
    Outer: M12649
    Inner: LM67048 (I think, could barely read it)
    I’ll order new bearings, but now the big mystery is what seals do I need? The old seals had no numbers on them.
    Still wonder what the rotors are from. The weird thing is that when I ordered the chevelle rotors that turned out to be wrong, I also order a set of pads that are listed for a 70 Chevelle, but the funny thing is that the pads are identical. So I’ll use the chevelle pads I guess.
    but anyway, given the above bearing part numbers, does anyone happen to know what seals I need? Thanks
  9. alchemy
    alchemy
    Measure the OD and ID of the seal and any part store should be able to find one.
  10. brading
    brading
    I would take my rotor plus the spindle size to my bearing supplier and they should be able to sort out a suitable seal
