Hot Rods Help ID this flathead
Discussion in 'The Hokey Ass Message Board' started by Rust Monkey, May 4, 2009.
  1. Rust Monkey
    Rust Monkey
    Ran across this flathead in a junk yard a couple of months back. It's in a early 50's Lincoln four-door. I know exactly squat about flatheads, so what am I looking at and would it be worth saving?
  2. alchemy
    alchemy
    Big Lincoln and big Ford truck flathead. I think they were 317's. Hard to find speed parts for, and also regular rebuild parts as well. Not recommended for a hot rod project.
  3. RPW
    RPW
    337 to be correct. If its a "baby-Lincoln" it shares the body with the Merc but frame is 3" longer than the Merc. The engine looks like it need somne work and parts for the 337 are quite expensive, not many speed parts available. Very few parts interchanges with the Ford/Merc. So there are a few better choices for a flathead...
  4. Little Wing
    Little Wing
    from Northeast
    337 2 versions Ford and Lincoln and i think 1950 Lincoln had Hyd Lifters..They weight more than a Hemi
    If its free take it other wise you are very limited on any kind of speed parts and the weight to HP ratio is well...lol
    heres an old homemade Tri Power unit for one
  5. Rust Monkey
    Rust Monkey
    Sounds like I'd be better off leaving this one alone. Thanks for help.
