help id this mallory dizzy
Discussion in 'The Hokey Ass Message Board' started by 32coupedeville, Jan 17, 2011.
  1. 32coupedeville
    32coupedeville
    from cincy
    i just picked this mallory distributor . i dot know what it fits. has a hex drive to the oil pump. here are some pics
  2. Crestliner
    Crestliner
    Probably help to list the tag info.
  3. 32coupedeville
    32coupedeville
    from cincy
    i couldnt find any part number.
  4. Blown Mopar
    Blown Mopar
    from abc
    That is a neat advance on the side. On my Chevy you have to remove the plate that holds module to get to an advance which replaces the va***n one
  5. 32coupedeville
    32coupedeville
    from cincy
    yes it has a neat advance on the side . just unscrew the set screw and advance or retard . it has a scale to.
  6. frankenfords
    frankenfords
    from SoCal
    Looks like a small block Ford. The hex in the bottom is for the oil pump drive shaft.
    Brett
  7. Weedburner 40
    Weedburner 40
    Probably small block Ford. I don't know of any others that use the hex drive for the oil pump
  8. 32coupedeville
    32coupedeville
    from cincy
    thanks for the info. i got this with a bunch of distributors. they were all malloy mag skark but the rest were all chevy. i had never sean a hex drive before.
  9. 460stang
    460stang
    small block ford 260-289-302 5/16 hex in the end for the oil pump drive.. i have that same dist. in my old 289 sitting in the shed..
  10. Kerri
    Kerri
    My guess would be without the specs. Ford FE 352,390,406,427,428
