Help ID This Pile-O-Transmissions!
Discussion in 'The Hokey Ass Message Board' started by Abomination, Apr 5, 2010.
  1. Abomination
    Abomination
    30. gm 4 8837552
  2. Abomination
    Abomination
    31. on shift plate 1a-7222
    extension housing r10e-7a wg div
  3. Abomination
    Abomination
    32. gm7 3858986
  4. Abomination
    Abomination
    33. ford....cant read the tag
  5. Ebbsspeed
    Ebbsspeed
    Jeez-O-Pete, there's a bunch of transmissions, so far I haven't seen anything that really jumps out at me, lot's of three speeds. The T85 (trans #3 & #18) I believe is a three speed Ford from the late 50's, with a cable-operated overdrive, so it might be kind of nice to have. The T86 (trans #4 & #16) is the same, later version of the Ford 3-speed with overdrive.
  6. Abomination
    Abomination
    34. t96-1 wg div
  7. Abomination
    Abomination
    35. ford hef ap
  8. Abomination
    Abomination
    36. ford rat 22
  9. Abomination
    Abomination
    37. gm 8744920 c152
  10. Abomination
    Abomination
    38. gm 1317854-1
  11. Abomination
    Abomination
    39. t86f-1 wg div
  12. Abomination
    Abomination
    40. gm18 b270 3925647
  13. Abomination
    Abomination
    41. extension housing r10f w2
    on shift plate 2228 wg div
  14. Abomination
    Abomination
    42. extension housing 1a-7651-a
    on shift plate 7222
  15. Abomination
    Abomination
    43. on shift plate 8a-7222
    extension housing 1a 7651
  16. Abomination
    Abomination
    44. on shift plate 7222
    extension housing 1a-7651a
  17. Abomination
    Abomination
    45. c-94251 72260-1
  18. Abomination
    Abomination
    And that's it - 45 transmissions. Feel free to holler out if there's anything interesting in there or worth keeping, or if y'all know what should be s****ped.
    Thanks a lot, guys - I kinda figured I'd bring these to the experts!
    ~Jason
  19. a4278v
    a4278v
    THE FORD BORG WARNER T-85-86 OVERDRIVE BOXES HAVE SOME VALUE but shipping makes it tough but you should be able to sell all the overdrive pieces and some of the reg 3 speeds. I wish you were closer.good luck Bruce.
  20. Abomination
    Abomination
    That's just the thing - he's not sure what he has. He found a part out there he thought was just a regular electrical part, and it turned out to be a crab distributor.
    There's a LOT of flathead stuff there, too - and the guy who he got it from MUST have kept some of the stuff because there was SOME value. I mean, there's at least a few Merc cranks there.
    If this goes well, I may post pics of his flathead pile, too. He's north of St. Joe, MO - on dialup. I'm here in Kansas City. He emails the pics, I post 'em.
    He also found a '57 Chevy 235. All these parts have been inside, and well protected until he moved them. He's moving them inside ASAP, but for now they're under tarps.
    ~Jason
  21. F&J
    F&J
    Number 40 looks like a non syncro first gear 58-up chev 3 speed...if it has a rear mount pad on the tail.
  22. F&J
    F&J
    number 29 is 51-up OLDS selector shift 3 speed.
    Number 27 may be a different version of 29 "IF" it is OPEN driveline like 29
  23. sodbuster
    sodbuster
    from Kansas
    Any baby flatheads? Also, did you ever get that ford motor running?
    Chris
  24. Abomination
    Abomination
    I haven't seen his flatheads, actually.
    As for the Ford motor, I lost like half my ba*****t in a flood a few months back - the water department never shut off my water after the heater broke and the pipes froze/burst, spraying everything for a week before I found out. Unfortunately, none of the car stuff is covered, and I'm having to go after the city for it.
    So the Ford motor got a little sidetracked, unfortunately - as did every other project. A running Hemi even got sprayed. :(
    ~Jason
  25. Abomination
    Abomination
    Anybody else have any ideas as to what some more of these are?
    Anybody see anything that should be s****ped right off?
  26. Truckedup
    Truckedup
    ******s as s**** are worth about 10 cents a pound.If you could break them up into piles of gears and shafts,and another pile of cast iron,be worth more.Cast iron ****** might weight 50-80 lbs each? Pull off side or top covers,rusted bad inside,s****.OD ****** have some value to some people.
    Looks like you got about 200 bucks of s****.
  27. 2muchstuff
    2muchstuff
    from Eastern KS
    I went up and looked at this pile of flathead parts last winter - had to roll large chunks of ice off the tarps to get a look at stuff. Personally I thought he was a little pricey on the flathead stuff. No V8-60's, although some 60 parts - cyl sleeves, pistons, rings, bearings, etc. The stuff is mostly old original parts like the 60 stuff, but not well taken care of, so many incomplete sets, bearings laying loose out of boxes etc. I didn't see any merc cranks a**** the ones I looked at, but there could be one buried in the mix somewhere. The flathead engines were dis***embled, so finding all the parts for any one engine might be tough. Most even had the main caps gone. I didn't see any 97's or speed parts of any kind.
  28. 55 dude
    55 dude
    #14 was in a A-100 van because the upper mount. gm and ford has similar mounting systems in their 60's vans.
  29. Piston Farmer
    Piston Farmer
    The Borg Warner trans T-85/86/90's where used in alot of different vehicles. if i was closer i woul scoop up one of the t86's for my nash. mine has no third gear!
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    #7 looks like 1955 Pontiac; same gearbox as Buick, but open drive tailstock.
    #23 is '50s to 1960 Buick H.D. three speed with six bolt inspection cover, as in Super/Roadmaster
    #24 is 1940-48 Chevrolet p***enger car
    #29 is either '51-'63 Olds (as someone already said), or '56-'57 Pontiac
    #30 is '55-'65 Chevy O/D
    #38 is Buick torque tube light duty trans with five bolt inspection cover
