Technical Help ID This Roof Section, Please
Discussion in 'The Hokey Ass Message Board' started by In_The_Pink, Jul 26, 2024.
  1. In_The_Pink
    In_The_Pink
    Picked up this roof section today, and could use some help identifying which car it originally came with/on. Seller thought Plymouth, so before I go down the rabbit hole, I thought I would try tapping into the collective knowledge here first.
    hrm2k likes this.
  2. The37Kid
    The37Kid
    NICE! That door hinge will help ID it, something unusual I'm sure. Bob
    hrm2k likes this.
  3. 52lomofo
    52lomofo
    35-36 ford 4dr ?
    Squablow and hrm2k like this.
  4. The37Kid
    The37Kid
    My first guess is HUDSON around 1936.
    Bob
    hrm2k likes this.
  5. choptop40
    choptop40
    I'm thinking Packard...
    hrm2k likes this.
  6. hrm2k
    hrm2k
    I was thinking Plymouth until the hinge picture.
  7. greybeard360
    greybeard360
    Why would you buy something without knowing what it was off of?
    Want to buy a hen way? $ .50 a lb.
    Just Gary likes this.
  8. In_The_Pink
    In_The_Pink
    Thanks for the leads, I will do some online sleuthing tonight to see if I can find the source.
  9. The37Kid
    The37Kid
    All the HUDSON Coupe photos I found won't let you copy them.Hope your luck is better. Bob
  10. The37Kid
    The37Kid
    All the HUDSON coupe photos I found won't let me copy them. Hope your luck is better. Bob
  11. In_The_Pink
    In_The_Pink
    It looks like a 1936 Plymouth 4-door Touring Sedan is a close match. The curve around the quarter window which ends as it touched the beltline, the warp of the beltline curve, the trunklid hinge position, where the back edge of the top insert ends, the rear door's upper hinge position, the grab handles, the shape of the rear quarter window lock levers, the position of the screw holes for the interior quarter window trim...:
    Fordors likes this.
  12. ronzmtrwrx
    ronzmtrwrx
    I believe you nailed it.
  13. choptop40
    choptop40
    cool that someone saved it...
  14. It looks like a good piece to use to convert an early 1930's sedan into a coupe.
