Customs Help! Ideas for 3” tail/marker light lens
Discussion in 'The Hokey Ass Message Board' started by Kosmos55, Dec 31, 2024.
  1. Kosmos55
    Kosmos55
    I need a lens 3” diameter. Can be amber, clear, or red. 2 or 4 mounting holes equidistant around the perimeter with 2.5” mounting screw spread.
    This is a custom application for the ‘55 and ‘56 Dodge front grille marker lights.
    Anybody know some source that is hamb friendly? Slight bullet shape is preferred.
    Let’s see what y’all got!
  2. 3quarter32
    3quarter32
    Ya Jim, caught that after I replied. Deleted now.
  3. choptop40
    choptop40
    I think 50s Buicks were 2 hole lenses..
  4. squirrel
    Old pickup trucks, but I don't have any to measure.
  5. Mr48chev
    Maybe one of the 56 Chevy guys can measure one of their tail light lenses. Another one to check is the 61-67 Corvette tail light. They also sell clear same shape back up lenses for those. Again I have no idea on their size but someone should be able to measure and you might be able to adjust the od of those a tad. Screenshot (1824).png Screenshot (1825).png
  6. squirrel
    The 58 Chevy lens (used on the 61-67 Corvette also) is a hair too large, and holes are in the wrong place, but it's close.
    If you don't need a reflector, just find Moriarty's thread on making lenses. Perfect for a custom car.
  7. nickleone
    nickleone
    Buy some acrylic sheet in a color you want (amazon) then cut your circle . Find a small bullet to glue to the circle. I found Buick red bullet lenses were about 1.5 in in diameter
  8. Kiwi 4d
    Kiwi 4d
    If you want to a law stickler ,red acrylic sheet wont p*** as there is no pattern to reflect light. What are the cool tail lights up top from ? Do you plan to have turn signals?
  9. ramblin dan likes this.
  10. Kosmos55
    Kosmos55
    Thanks for the replies.
    I’ve tried ‘61 Chevrolet car, no good.
    The lights on top are ‘62 Monterey wagon.
    I was trying to find something of that era, just having trouble dimensionally.
  11. Kosmos55
    Kosmos55
    I might try heating some sheet and rolling it like a cinnamon roll. Maybe a triangle shape so it forms a cone?
    Not good at converting my idea to words but looks pretty cool in my head!
    anthony myrick likes this.
  12. I’ve seen heat used to form plastic over a formed shape.
    The stuff I posted was 1/8 thick. I’ve seen thicker material out there. Would probably need that if using a deep form
  13. In_The_Pink
    In_The_Pink
    '59 Edsel?
    3-9/16" O.D. at the base flange, 3-1/16" O.D. at the outer end, 1-3/4" tall:
    anthony myrick and Just Gary like this.
  14. pprather
    pprather
    Lens and surround, 33-36 Ford, don't know exact diameter.
  15. Jokester
    Jokester
    Some long dormant brain cell of mine tells me that red lights are not legal on the front of vehicles, except for emergency vehicles. You might check local laws before you spend money.
    .bjb
  16. Kosmos55
    Kosmos55
    Thanks for looking out but these are for the rear of the truck. Not front of the Dodge anymore.
    SS327 and Kiwi 4d like this.
  17. You can get acrylic sheet to soften and will lay over a shape (laminated timber, made into a cone shape on a lathe).
    It will soften at about 90degrees Celcius in your oven on low. Just remove it when it looks about right and let it cool, then trim any excess bits off. You can even make a male/female mould and soften the sheet then clamp in between.
  18. 5window
    5window
    Nice work, and lots of reasonable suggestions. Maybe contact a tail light lens vendor like
    http://www.taillightking.com/ who knows their inventory? In hindsight, I suspect you're thinking it might have been a good idea to access the lenses before building the housings? I, myself, usually don't plan that far ahead.
    vtx1800 likes this.
  19. 51504bat
    51504bat
    I was thinking '54 Ford. 3" diameter but 3 holes not 2.
  20. BJR
    BJR
    Don't have one to measure, but you might look at 54 Buick also.
  21. Kosmos55
    Kosmos55
    Mostly good suggestions, I like the Ford shape.
    The reason I’d like to find something that already exists rather than make my own is the brake lights above them. Homemade looks off next to OEM. image.jpg
    5window, duecesteve and Tim like this.
  22. SS327
    SS327
    Sure would like to see more of that truck.
  23. RICH B
    RICH B
    When I looked at the pictures; I thought exhaust tips, enough lights on top already.
    51 mercules and 5window like this.
  24. swade41
    swade41
    from Buffalo,NY
    These are some kind of mopar, I forget which
    duecesteve, SS327 and anthony myrick like this.
  25. Taboo56Chevy
    Taboo56Chevy
    While I dont know the sizes but some ideas that might work:
    40s-60s Motorcycle? Like a Harley, Indian, or something, they usually had 2 bolt lenses for turn signals.
    55/56 Pontiac Reverse Lights[​IMG]
    49-52 Chevy car reverse lights
    reverse light for a 60-66 Chevy C10 fleetside truck
    I think looking at clear reverse lights might land something that will work over a red tail light lens.
  26. rdscotty
    rdscotty
    from red deer
  27. Kosmos55
    Kosmos55
    Thanks for the suggestions everybody. I have some H-D turn signals that will work for now but it’s to see these other options.
    I originally thought of exhaust tips but the routing would be very involved and would need holes or notches in the bottom of the rear fenders.
    On another topic, maybe we can start a kind of database on here to help prospective customizers. Like listing options based on shapes and sizes? Including mounting?
    Here’s a couple recent pictures:
  28. X-cpe
    X-cpe
    Truck is gorgeous.
    Triumph Spitfire from the early to mid 60's.
    3 and a fat 1/8" dia.
    not quite 2" tall
    2 1/2" across the screw holes
    diameter is slightly reduced below the line just up from the bottom
    could easily be shortened up to about 5/8" if need be
  29. Tim
    Tim
    from KCMO
    Bet a 56 olds would be pretty close
  30. Tim
    Tim
    from KCMO
