Help identifing Mallory distributor
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Dec 27, 2012.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    I need help identifing this Mallory dual points distributor.There isn't a "series"tag on the outside anywhere.The parts house needs a "series#"to ***ist me.Want to order a cap etc.Where/who can I call?
    Tag on outside says:Mallory ignition dual life distributor part#1018001
    1960 235 6cyl engine
    THANKS in advance
  2. PackardV8
    PackardV8
    When you find out, I hope someoone has a link to an old Mallory part number sheet.
    Even better, I hope your distributor uses Mallory #135 points. I have two sets in original Mallory packaging.
    jack vines
  3. hd4unm
    hd4unm
    Look up Mallory on the web and call them, they are usually quite helpful. They have been to me.
  4. tomcat11
    tomcat11
    YC Series Double Life. They don't make the caps anymore. Your best shot will be e-pay or the good ole HAMB. GMC Bubba on here may be of more help. I think the cap p/n is #4002.
  5. jimmy1931
    jimmy1931
    My local NAPA guy and Hamb member used an old Mallory catalog he had & part numbers from my points to track down new points, rotor, and cap. Took about an hour on the computer and came from plant in Virginia.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Just a thought: If you can't obtain the right cap maybe you could make an adapter ring that fits over the distributor base and enables you to use a common late model cap.
  7. fenderless
    fenderless
    from Norway
    My parts supplier said that they have started to make the 4002 again!:)
    Taildragger&fenderless
  8. fenderless
    fenderless
    from Norway
    Sorry must had one too many! didn't think as this is for a six.
  9. dtwbcs
    dtwbcs
    from Brenham,TX
    YC series,okay that is a start.Also want a new rotor;anyone know that part#?
    Thanks in advance
  10. 24riverview
    24riverview
    Left this kinda large so it was readable, from mid 70's catalog.
  11. tommy
    tommy
    Don't throw away your old cap. Inspect it very closely for cracks and then if none are found it can be easily cleaned by bead blasting with worn out beads or baking soda. Once all the corrosion is gone inside the cap the exterior can be restored by dusting with clear so that it looks brand new. The caps are bullet proof when compared to factory throw away caps. Check the carbon contact inside also.
  12. hd4unm
    hd4unm
    I think this is good advice.
    Have always wondered what could go wrong with a cap besides being broken or looking carefully for arc trails in the dome. A good cleaning has revived a few for me. It takes a lot of firing before there is any noticeable wear as far as I can see.
