Hot Rods Help identify gauge cluster?
Discussion in 'The Hokey Ass Message Board' started by Jeff's '29 Roadster, Apr 11, 2017.
  1. IMG_2889.jpg Hi there.....anyone have any idea what this gauge cluster is or if it's worth anything?
  2. BJR
    BJR
    Chevrolet 1933 Mercury
  3. Thank you so much......I'm guessing not appropriate in a traditional 1929 roadster build? Think the gauges are worth taking out and putting in another cluster? The guy wants $75
  4. BJR
    BJR
    If you like it use it.
  5. 302GMC
    302GMC
    from Idaho
    Should work great as long as your charging system doesn't exceed 20 amps & the oil pressure is never higher than 30 lbs.
  6. Well now throw a flatty between the frame horns and you're golden. ^^^^ :D :D
    @Jeff's '29 Roadster why wouldn't it bean appropriate piece for a traditional '29 roadster build? Its a gauge panel and its got gauges.
  7. fleetside66
    fleetside66
    That's a great panel for your build, period and style-wise. But, what Porkn****** says about the amps and pressure gauges is definitely a consideration. Good price, too. The AC speedo is way under appreciated compared to the equivalent S/W. Go for it.
    slv63 likes this.
  8. AC gauges in general are way under appreciated and way more rare. If I needed something for my A sedan I would be all over it. pretty neat little panel, needs a little cleaning up for my taste but that is just a tooth brush and some comet away. ;)
  9. Bruce Lancaster
    Bruce Lancaster
    Pro restoration tip: ALWAYS use someone else's toothbrush.
    BJR and slv63 like this.
  10. Bruce I know a pretty funny story about that. :D
    hey while you're here you got any history on AC gauges? You are always pretty good with really obsolete stuff?
  11. Bruce Lancaster
    Bruce Lancaster
    AC gauges are good stuff...they made a lot of simple round gauges long after cars went to little rectangles because they supplied stationary motors, huge construction machines, heavy trucks, etc. They made some nice hotrod type gauge panels just like SW, and I think they are only obscure because they did not see and jump on the hotrod market for industrial gauges. I've never found an AC aftermarket catalog, so I have no idea what's out there beside the panel and a few gauges I have. Their stuff is as nice as SW.
  12. Thanks
    Seemed like I saw some being used a long time ago but I never really knew the story on them. ;)
