Technical Help identify spindle
Discussion in 'The Hokey Ass Message Board' started by hotroded, Feb 5, 2018.
  1. Need help identifying this spindle set up
    Its in my 41 willys .
    Yes wildwood brakes
    Spindle mount ?
    Will get better pictures when it gets above 12 degrees.
    Thanks[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my VS988 using The H.A.M.B. mobile app
  2. 1934coupe
    1934coupe
    It certainly looks like the spindles I've had on my Willys. A stock Willys spindle.
    Pat
  3. alchemy
    alchemy
    Itsa Willys axle. Isn't it a Willys spindle?
  4. great thanks needed a starting point for brake up grade and wheels
  5. millersgarage
    millersgarage
    upgrade from Wilwoods?
  6. Its a jigsaw puzzle to get apart to take the wheel off need something a little easier to change a flat
  7. 1934coupe
    1934coupe
    I'm not sure but I think all you need is a non-spindle mount hub. The rotor and hat should bolt to it. Call up Wilwood or look in catalog. Take that super trick away from there and let's see a picture of the hub and rotor from that side.
    Pat
