Help Identify these wheels
Discussion in 'The Hokey Ass Message Board' started by Gas_Tires_Oil, Jul 15, 2013.
  1. Gas_Tires_Oil
    Gas_Tires_Oil
    I found an old home made Utility Trailer at our town dump recently that I'm going to build a single motorcycle trailer out of. Can someone help identify these wheels? They're 19" and are 6 lug. I appreciate any help. Thanks
  2. Phillips
    Phillips
    Wild guess says Chevrolet
  3. Gas_Tires_Oil
    Gas_Tires_Oil
    Trying to upload more pics... argh
  4. Springs, shocks, axle and 6-bolt pattern......all says Chevrolet!
    But I could be proven wrong......Naaahhhh! :D
  5. F&J
    F&J
    that type of spring shackle with a bolt holding the center together is on mopar and chevy for sure. Mopar would be hyd brake, chevy would be mechanical.
  6. Gas_Tires_Oil
    Gas_Tires_Oil
  7. summersshow
    summersshow
    from NC
    About a '32 Chevy truck... Cars have a broader center...
  8. F&J
    F&J
    Not on the earlier chevys, the wheel you are thinking of is later 17", around 34 or 35
    The earlier 19 chev wires are same in car and pickup.
  9. summersshow
    summersshow
    from NC
    Learn something new every day... Thank you F&J.... Im only aware of the appearance, not the sizes haha
  10. F&J
    F&J
    There is also a real strange chevy wire wheel from around 33. It was on the cheapest chevy model, called the Mercury. It was 5 lug, and has a 4-1/4" bolt circle that no other car had. If you spot one, the bolt circle will grab your eye, as it just looks small.
    The fat hub wire wheel would have been on the bigger Master series.
  11. Gas_Tires_Oil
    Gas_Tires_Oil
    So it's a 1932 Chevy truck or car? Here's a pic of the trailer itself. I almost fell over when I saw it at the dump. With it having the dropped I-beam axle it's perfect for a low drive-on motorcycle trailer. Can't wait to jump on it. I'm going to tow it behind my 31 A. Thanks for the help.
  12. F&J
    F&J
    Actually, Most 32 cars were 18" I would say around 30 31
  13. Gas_Tires_Oil
    Gas_Tires_Oil
    Ok thanks F & J and everyone. I appreciate it! :cool:
