Technical Help Identify this engine
Discussion in 'Traditional Hot Rods' started by MikeG5211, May 19, 2020.
  1. MikeG5211
    MikeG5211
    Block.jpg VIN.jpg Thanks
  2. nobby
    nobby
    what the 32 and 4 near the GM about?
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    TJZ 1973 350 155 hp
    31hotrodguy likes this.
  4. nobby
    nobby
    VO319TJS
    OOH please do mine sir!!
    2 bolt 350
    461 heads - camaro I think
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    TJS 1979 350 165hp
  6. nobby
    nobby
    what does the vo 319 translate to ?
  7. nobby
    nobby
    Moriarity likes this.
  8. harpo1313
    harpo1313
    from wareham,ma
    could of said corvette
    mgtstumpy likes this.
  9. studebakerjoe
    studebakerjoe
    Seems like they're all out of corvettes. I didn't know they made so many.
  10. 31hotrodguy
    31hotrodguy
    And There is nothing wrong with a good early 70’s 010 block as long as your not too picky about nostalgia an or know how to make one look older. [emoji1303]
    egads and Moriarity like this.
  11. Peter Nowak
    Peter Nowak
    3970010 Small Block V8 1969 302, 4 bolt, Camaro Z28
  12. Fordors
    Fordors
    @nobby, I don’t think the seller necessarily lied to you. You have a ‘79 block and ‘461 heads that were produced from ‘62 to ‘64, it is an engine put together from random pieces.
    Just as easily the engine could have been put into a Camaro and the seller removed it from that car without knowing the origin.
  13. Ericnova72
    Ericnova72
    from Michigan
    "V" - Flint Engine Plant
    "0319" - it's date code, "03" = 3rd month, March. "19" = day of month, 19th
    Nothing would be different between a 1979 Camaro 350 and a 1979 Truck 350....except the truck would be more likely to have a 4-bolt main cap engine. Everything else would be the same...same 4 barrel intake, same camshaft, same heads, etc....even same hp rating. Even if it came from a 1979 Z28, by this late in the smog engine era nothing was special about Z28 or Corvette engines.
    Only if the front application suffix stamped code ended in "DZ"....the posted "TJS" is definitely not a 302.
    Truckdoctor Andy likes this.
  14. Ericnova72
    Ericnova72
    from Michigan
    Just sand core or internal tracking numbers used at the foundry. Nothing significant to the ID or finished specifications of the engine or the block.
  15. Black Panther
    Black Panther
    from SoCal
    I've mentioned this on other threads, but I'll do it again here for a different set of eyes. Any application code that starts with a T...is from a truck. You don't need to know the other two letters for a quick decision if someone is selling you a Corvette 350. Same holds true for big block... when they went to 3 letter codes.
  16. Ericnova72
    Ericnova72
    from Michigan
    Same is true for letter code portion starting with "U", "V", "W", "X", and "Y" also, always truck codes for small blocks, and big blocks with a few BBC marine engines in the mix.
    For some reason with the letter "Z" , on SBC's Chevy went back to using it on both cars and trucks, but most all "Z" codes are high performance engines, Vette and Chevy II along with some truck.
    No "Z" code Big Blocks.
  17. Peter Nowak
    Peter Nowak
    Live and learn. pulled that off a chevy block id site.
