Technical Help Identify This Rear End - Pics
Discussion in 'The Hokey Ass Message Board' started by EPeters85, Dec 21, 2021.
  1. EPeters85
    EPeters85
    from No.VA
    Hey folks, anyone have an idea what rear end this is?
    Deuces likes this.
  2. Fordors
    Fordors
    It's a GM 8.2 ten bolt rear, the ring gear diameter is 8.2" and the lack of the protrusions on the top of the casting for the upper control arms say it came out of a Camaro, Nova or other leaf sprung vehicle.
    Deuces, mgtstumpy and Max Gearhead like this.
  3. Guy Patterson
    Guy Patterson
    What is it going behind? If aI6 will be fine but if a healthy V8 look for better
    Deuces likes this.
  4. EPeters85
    EPeters85
    from No.VA
    Awesome, thanks for the info. I was told it might be out of a late 60s/early 70s Chevelle, so I suppose its probably true.
    It's already installed behind a healthy 350 sbc, but nothing crazy. Probably won't see the track or anything.
    Deuces likes this.
  5. saltflats
    saltflats
    from Missouri
    Not out of a Chevelle, doesn't have the upper trailing arm mounts.
    Unless they have been cut off and we can't see it from your pictures.
    Deuces likes this.
  6. 38Chevy454
    38Chevy454
    GM used the 8.2 inch 10-bolt in many cars with stock 6 cyl through mild to warm small blocks. Most big blocks received heavier duty rearend. But that 8.2 will probably hold up just fine with street tires. You'll break traction before you break the rearend. Think about how many people use S-10 rearends (7.625 inch ring gear) behind some performance small blocks. They hold up for most part, although I personally think they are too weak. The 8.2 is stronger than the S-10. GM also had an 8.5 inch ring gear 10-bolt, used in years after the 8.2 (approx 70-80's, but some later use). That rearend can take a lot more abuse than the 8.2. All of the 7.625, 8.2 or 8.5 are c-clip style axle retainers.
    Deuces and gimpyshotrods like this.
