Technical Help identifying 327
Discussion in 'Traditional Hot Rods' started by 63bigbird, Nov 20, 2013.
  1. 63bigbird
    63bigbird
    I have a 327 I just acquired, I would like for the 327 gurus to help enlighten me on what I have. I have used the search function and did find out it is indeed a 327 and from what I have read it is a 1965. But the rest is over my head. Here are the numbers # on rear of block drivers side-3782870. Stamping at rear of block behind distributor-E55. Stamping on front ledge p***enger side-F05I4HA. Plans are to try to put it back original if its desirable.
    Thank you for the help
  2. hot rust
    hot rust
  3. 63bigbird
    63bigbird
    Been there and read that earlier. That's where I came up with 62-67 car-truck two bolt and it was 65 year. Thanks for the link though.
  4. Larry T
    Larry T
    Looks like HA (in 65) was a 275 hp 327 / 4 speed.
  5. 63bigbird
    63bigbird
    Thanks, wasn't sure if the front stamping was a form of identification. Is it safe to say that hopping it up a little wouldn't hurt the vintage factor?
  6. squirrel
    The front stamping tells you the engine factory (F is Flint MI), the date the engine was ***embled (May 14th) and the application (HA is full size Chevy with a 327 250 HP manual transmission). The date is not there, but you gave that with the casting date from the rear of the block E 5 5 is May 5th, 1965 (my fourth birthday).
  7. 63bigbird
    63bigbird
    Thanks for the information. The knowledge you guys have is amazing. Planning on putting it in my 54 210. Thanks
