Awesome, I need one for my T! How to test it to see if it's good? I can't get it to turn with no steering wheel.
Loosen that clamp and pull the tube off. Now you can use a Vicegrip on the shaft itself without damaging anything.
Took a little mallet work, but once I got the tube off, it turns like ****er. I must've bought this thing 20 years ago and forgot I had it until I found it today, looking for the axle from a banjo rear end. Now if I could only find that...
Might want to read through this one https://www.jalopyjournal.com/forum...x-rebuilding-for-early-fords-f1-f100.1347486/
If you don't find the missing Axle measure the other one and count the spider gears and P.M. the numbers to me. I have a mess of unlabeled pre 49 loose axles. Pretty good chance I can help you out.
