Technical Help identifying Mallory dizzys
Discussion in 'The Hokey Ass Message Board' started by jtrod49, Nov 12, 2016.
  1. jtrod49
    jtrod49
    Picked up two Mallory dizzys supposedly for a gm 216/235 best research I could do says they are but just want to make sure only difference it the shafts? Help anyone any info would be greatly appreciated [​IMG][​IMG][​IMG] [​IMG]
  2. Fordors
    Fordors
    I can't help with info on the correct applications but I can give some insight into their operation. The YCM was intended to be used with the Magspark Transformer but it can also be set up to run with a conventional coil. With the MS transformer the points are independently connected to the Magspark, but for regular coil use you need to have a jumper wire connecting the two point sets. Mallory recommended it only be converted and used with their Voltmaster coil but you might ask GMC Bubba what coil would work. The Y means it is centrifugal advance only, C tells us it uses #24875-B points and a #24878 breaker plate and the M suggests it is for use with the Magspark, unless someone modified it as mentioned above. Your other one is Z, for both mechanical and vacuum advance and the C as above.
  3. stillrunners
    stillrunners
    from dallas
    good info Fordors....
  4. jtrod49
    jtrod49
    Well when I bought all his it came with a coil and resistor that was all packaged together so could it be a magspark or would it clearly be indicated and mark on the coil if so ?
  5. jtrod49
    jtrod49
  6. Fordors
    Fordors
    The 12V Mallory Voltmaster had a 2" diameter resistor mounted on it but I believe the 6V coil had none. The Magspark is much larger and is kinda boxy, with two resistors on it as compared to the round Voltmaster coil. Also the VM is identified by the high tension lead having a rectangular retainer that is held down by two screws.
    jtrod49 likes this.
  7. 24riverview
    24riverview
    The 180 is for early 6's (216-261), the 476 is for later 6's (194-292).
    jtrod49 likes this.
  8. jtrod49
    jtrod49
    Thanks I guess I just have a standard could it looks ordinary but has no markings appreciate all the great info !
  9. jtrod49
    jtrod49
  10. jtrod49
    jtrod49
    So the shaft I'm ***uming is really the main difference besides the points that they used? So I guess when looking for a distributor for 216/235/261 it'll be a longer shaft also on the 180 looks like some sort of condenser or vacuum what's that all about?
