Hot Rods HELP!!! identifying parts
Discussion in 'The Hokey Ass Message Board' started by guilld, Oct 18, 2023.
  1. guilld
    guilld
    I need help identifying these parts. I plan on selling hopefully to someone in the swap meet business. These parts are in a storage unit near Nashville Tn.
    I have been told this is a Pontiac motor. I have looked on the block front left and rear around the distributor for a number but not luck. The left side of the motor is totally covered with the alternator and power steering.? I can tell the water pump is not chevy.
    Also is the ****** a 350 or 400?
    The rear end is a banjo with mechanical brakes lugs 5 on 5 1/2?
    The flat head 6 has a ****** with a emergency brake on the drive line. Is it Chrysler? Is it worth anything other than a boat anchor?
    Hopefully I have posted this correctly with the pics.
    IMG_1503.JPG IMG_1504.JPG IMG_1504.JPG IMG_1504.JPG IMG_1505.JPG IMG_1503.JPG IMG_1503.JPG IMG_1503.JPG IMG_1504.JPG IMG_1505.JPG IMG_1509.JPG IMG_1541.JPG IMG_1542.JPG IMG_1544.JPG IMG_1538.JPG IMG_1550.JPG IMG_1549.JPG IMG_1505.JPG IMG_1506.JPG
  2. treb11
    treb11
    Definitely a Pontiac. With a 2bbl carb, the trans is most likely a T350. HEI says 75 and newer.
    Diff looks like Model A to me.
    Dash is Chevy AD truck
    alanp561 likes this.
  3. carolina chevrolet
    carolina chevrolet
    i think Dodge on the flathead and fluid drive transmission. Someone would like to have it but it's not a high dollar item.
  4. WiredSpider
    WiredSpider
    Rear axle is early 32 Ford.
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Chrysler engine circa late '40s to mid '50s. Measure the length of the head to see which displacement it is. 23 inch is 230 cu. in. (Dodge & Plymouth) and 25" is 251 cu. in. ( Chrysler). Fluid Drive transmission is a little hard to put a year to as it was used for so many years. It could be an M-5, judging by the external band emergency brake. In the '50s they went to an internal expanding brake. It could be an M-6 because at some point they went back to the external contracting band for a little while. I have one of each in my bag of tricks. If Ted at 302GMC sees this, he can tell you more. Very knowledgeable man.
    05snopro440 and alanp561 like this.
  6. Jalopy Joker
    Jalopy Joker
    should put more info in ***le of thread
    5window, Beanscoot and alanp561 like this.
  7. guilld
    guilld
    I do not know how to edit a ***le? Thanks for the info so far. Where are the identifying numbers on a Pontiac?
  8. Mr48chev
    I'm not sure I'd go to the effort to haul that Pontiac engine and trans to a swapmeet. I'd stick it on craigslist or marketplace for 2oo bucks and the first cash in hand offer I got for it, I'd be telling them to back the truck in and we will load it. The AD truck dash isn't worth a lot as somone hacked it up putting a different radio in it but there is enough there to patch someone's worse hacked up dash.
  9. Deuce Lover
    Deuce Lover
    TO EDIT ,To the right below your ***le is THREAD TOOLS and WATCH THREAD.Click on THREAD TOOLS and you can make the change .
    lothiandon1940 and Budget36 like this.
  10. 05snopro440
    05snopro440
  11. 5window
    5window
    BJR likes this.
  12. guilld
    guilld
    Thanks for the info. I am trying to get some value on this stuff. I own a storage facility and the guy renting the unit moved and asked if I could get rid of what was in the unit. I did not look in the unit and said sure thinking it was you know household items that I could auction or easily haul to the dump. When I opened it up I knew an auction was out of question. I doubt if I could get a bid. I could but I hate to take this stuff to salvage because someone could save it. I really want to bundle this stuff and give someone a deal on all of it of course they have to be near Nashville.
  13. guilld
    guilld
    Thanks!
  14. guilld
    guilld
    Well it is 25 inch so the 251 cu. in. Thanks for your help
