Technical Help identifying rear end & transmission
Discussion in 'Traditional Hot Rods' started by modagger, Apr 27, 2020.
  1. modagger
    modagger
    88772789-7E53-470E-B0F8-0B26BBCC162B.jpeg 6F78BCB3-7155-4D3E-905B-3D68E23FF947.jpeg 5DF38E29-59BD-4C4D-8C79-2FC91B414202.jpeg Greetings All
    Because I didn’t build my car, I need help putting the puzzle together please.
    Hopefully the photos will help.
    Thanks!
  2. indyjps
    indyjps
    Cant help on the ident, of 47/11 is indicative of gear ratio, its pretty steep.
  3. squirrel
    looks like a rear from an early to mid 50s ford, either wagon/delivery/pickup, and a mid 60s transmission. The rear is a ****er 41, and the trans is a Ford top loader 3 speed with the 1965 and later design case.
    Pictures that show a bit more of everything, instead of just the details, will help.
  4. modagger
    modagger
    E2AE3261-863F-4948-8BBB-09B2A9F58447.jpeg My concern is that I run out of 1st. gear very quickly. It seems to be geared pretty low for the weight of the car. I don’t know if it’s the transmission or the rear end or possibly both that are geared low.
    Here’s a full on shot of the rear. I can’t get a better one of the trans.
    kidcampbell71 likes this.
  5. CRYOMAN
    CRYOMAN
    from so cal
    Looks like That's out of an old Jaguar and looks like it has 4.27 gears. 4HA model designation more specifically. Very similar to an old Dana 44 but with bolt on hubs at the wheels.
    squirrel likes this.
  6. squirrel
    The transmission is 1:1 in high gear, but the rear end gears are very steep, as he said.
  7. modagger
    modagger
    4.27! Well that sure would ‘splain why I run out of 1st. gear so soon. Even in 2nd. and 3rd. It seems too low.
    Any remedy suggestions would be greatly appreciated.
    Thanks
  8. squirrel
    Johnny Gee likes this.
  9. modagger
    modagger
    Cryoman, I have no doubt that you speak truth, but I don’t understand why a Jag rear end would have U.S. patent numbers on it. Would you mind schooling me?
    Thanks
    Jeff
  10. sliceddeuce
    sliceddeuce
    Sourced from ****er Dana perhaps?
  11. modagger
    modagger
    Squirrel
    I followed the link you provided. If my conversion calculations are close, that gear set is about 750.00 before shipping. Is there a “Walmart” equivalent that you know of or is that price good?
  12. Jokester
    Jokester
    Or go to taller tires!
    .bjb
  13. mkubacak
    mkubacak
    A cursory search appears that maybe Dana 44 gears will work. Look further or contact a vendor like Randy's Ring and Pinion and see if that is the case.
  14. CRYOMAN
    CRYOMAN
    from so cal
    Car manufacturers share capacity all the time. Not uncommon for Dana/****er to build things for other companies and fit whatever tubes/axle ends required for the build.
  15. CRYOMAN
    CRYOMAN
    from so cal
  16. squirrel
    Again, what wheel bolt pattern does it have? I don't know what the rear is actually from, there were several vehicles that used the ****er 41 rear. I had a 59 Chevy pickup that came with one, six lug. Ford cars used them with 4.5" bolt circle, Ford trucks with 5.5", I think Jags used 4.75" bolt circle, and someone mentioned something about different hubs.
    More info needed!
  17. CRYOMAN
    CRYOMAN
    from so cal
    These rear ends, in Jaguars, came with a bolt on hub at the wheel. These were commonly found in Jaguar XK's.
  18. CRYOMAN
    CRYOMAN
    from so cal
    upload_2020-4-27_15-13-54.png Here you can see the bolt on hub.
  19. modagger
    modagger
    12CF40AC-5513-4680-99A7-2776840DE80A.jpeg Just finished dinner and now I’ll digest all the info sent my way!
    Here’s a photo of the rear brake ***embly if that helps. The bolt pattern is 5 X 5 1/2
  20. CRYOMAN
    CRYOMAN
    from so cal
    Interesting. Looks like those are one piece axles. Hmmmm
  21. CRYOMAN
    CRYOMAN
    from so cal
    Its entirely possible, given the one piece axles that its a Dana 41 out of an old jeep. Hard to say for sure but its definitely a Dana 41 center section. Out of what exactly? Who knows. The ratio tag looks identical to the Jaguar units I've seen in the past that's what led me to the Jaguar connection but the one piece axles points more to a jeep axle especially with the 5X5-1/2 pattern. Hope that helps.
  22. squirrel
    Hnstray and Truckdoctor Andy like this.
  23. Try searching part and patent numbers.
  24. bill gruendeman
    bill gruendeman
    Jaguars did use a lot of American parts. For years they used a ****er 44 rear ( just like a old old Dana 44 ) Jim you are right they did have 4 3/4 bolt circle.maybe it’s an old Dana 44 out of a ford truck? Dana 44 has been around since about ww2
  25. squirrel
    it says 41 right on it, it's not a 44. The cover is a different shape, also.
    Hnstray likes this.
  26. squirrel
    The 7006 number just means that it's a transmission case. The C5AP thing means it's for a 1965 full size car. (although other applications could use the part, and it could have been used for several years).
    Truckdoctor Andy likes this.
  27. Okay. OP should look for a tailshaft housing p/n and transmission tag, then look at toploader info, which would likely narrow it down.
  28. modagger
    modagger
    Whew! So much information. I thought for sure I would get responses like, “oh, that’s easy, you’ve got X,Y,Z. Wishful thinking on my part.
    I’m going to put it up on stands tomorrow and try to find some more info, tags, etc.
    It starts up front with a great running Y block so I’m hoping that it’s Ford all of the way back. We’ll see.
    Thanks everyone
    Be well
    Jeff
