Technical Help identifying this bent spoke wire wheel
Discussion in 'The Hokey Ass Message Board' started by kgjevre, Nov 29, 2018.
  1. NormB1
    NormB1
    Looks like 5 by 5.5 inch bolt pattern 16x4 inch 40 bent spoke (not adjustable) wire wheel with a 5.75 inch hub cap opening.
    Inside it has the markings US PAT PEND and KH so presumably Kelsey-Hayes?
    NOTE that it has a flat indentation around the valve stem hole that I have not seen on any of my other wheels, so I am extra curious about this and what car it was made for.
    Thanks!
  2. Baumi
    Baumi
    this is a 32 Buick wheel.... Looks pretty similar to me... what do you think?
    Texas Webb and chryslerfan55 like this.
  3. 302GMC
    302GMC
    from Idaho
  4. alchemy
    alchemy
    Yup, a 16" bent spoke Kelsey-Hayes meant for a 28-35 Ford. I'd guess the divot at the valve stem is just a production revision thing. Your's might be early, or late, production.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Looks like the 16" Bent spoke Kelseys on my Mordor. HRP
    kidcampbell71 likes this.
  6. Texas Webb
    Texas Webb
    The Buick wheel is wider,the short spokes on the inside are longer than the Ford and the bolt circle is 5 on6".Mine are made by motor wheel.
  7. F&J
    F&J
    Take a very close look at the wheel in post one below:
    https://www.jalopyjournal.com/forum/attachments/img_0149-jpg.4111667/
    then look at the catalog pic that 302 put up..and the close up of HRP's red wheel..
    the Ford wheel's longest outside spokes do cross twice, but the crossing at the hubcap point, they cross much more than the OP's wheel. The Op's wheel spokes barely cross there at the cap hole area.
  8. NormB1
    NormB1
    Thanks for the information guys!
    I took a picture of my wheel from about the same angle as the red wheel and I think they look pretty much the same, including the crossing of the spokes near the hub.
    F&J likes this.
  9. tub1
    tub1
    from tasmania
    The centre section is ford to me I've lots of Kelsey's on various cars only Ford has this centre
    kgjevre likes this.
  10. F&J
    F&J
    Maybe confirm it with somebody giving the Ford Hub Cap hole measurement? If it was a non-Ford wheel, chances are fairly high that the hole size would be different.
  11. NormB1
    NormB1
