Hot Rods Help identifying this distributor part
Discussion in 'The Hokey Ass Message Board' started by Dave Gray, Aug 8, 2024.
  1. Dave Gray
    Dave Gray
    My friend gave me this distributor part today. It looks like it mounts on the base of a distributor to set the timing. I have seen these on order cars, but I can’t quite figure out how this is installed on the distributor since there is no keyway or pin to hold it in place. Also, I would be interested in knowing What kind of car it came from.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    Looks like a spark plug gapping tool. Is the edge where the numbers are tapered?
  3. Mr48chev
    I'd say that it is a tool rather than a part. Made to set in a specific distributor to check or set the advance.
    19Eddy30 likes this.
  4. Dave Gray
    Dave Gray
    There is no taper on the edge. I don’t think that this is a tool. It looks more like a
    Distributor part.
  5. 69fury
    69fury
    from Topeka
    The center hole is only like 1/2 inch, so that will narrow it down quite a lot.
    The curved slot is for the lock down feature, and since it has a zero with a 15 before and after, it's definitely timing and not a plug gapping tool.
    Possibly mounts inside the cap, where the shaft is bare instead of around the shaft housing?
    twenty8 likes this.
  6. Dave Gray
    Dave Gray
    -rick[/QUOTE]
    whether it mounts at the base of the distributor or in the cap, I still think that it needs to be keyed or pinned in place otherwise it would just float around having no meaning.
  7. 19Eddy30
    19Eddy30
    from VA
    I would say like others
    Deg of setting advancement / tool
  8. Could have gone on the steering column from something in the '20's or '30's. Can't imagine 75 degrees advance though.
    rattlecanrods and Budget36 like this.
  9. Budget36
    Budget36
    Was about to mention that as well.
    Can’t be for gapping, the #’s appear to be outwards, not recessed.
    75 degrees?
    May not even be for a distributor.
    What’s it for, not a clue:)
  10. RodStRace
    RodStRace
    NOT a gapper.
    Exact use I can't help you with, but could bolt up similar to /6 dist. plates.
  11. Dave Gray
    Dave Gray
    I am beginning to think that this is a tool rather than a car part. I can’t think of a reason to have numbers on both sides if it is a distributor or car part. ?????
    lowrd likes this.
  12. brando1956
    brando1956
    Looks like the miter scale on a Skil saw. Usually they will only go 15 or so degrees one way and a larger amount in the opposite direction. Most are retained by a wingnut with a pointer to measure the angle of the cut.
    69fury, Algoma56 and BJR like this.
  13. Harv
    Harv
    from Sydney
    Brandol956 is right - zero to seventyfive degrees sounds like something that is only useful when measured up to ninety degrees..
    Any chance this is an elevation gauge from something that points skyward - artillery, construction/surveying gauge?
    Cheers,
    Harv
    Algoma56 likes this.
  14. Dave Gray
    Dave Gray
    Thank you for all of your replies. I still have not figured this little part out yet.
  15. 69fury
    69fury
    from Topeka
    whether it mounts at the base of the distributor or in the cap, I still think that it needs to be keyed or pinned in place otherwise it would just float around having no meaning.[/QUOTE]
    I think the wings at 9 and 3 oclock must locate against the mating part to keep it from floating around. I'm starting to lean towards the other guys talking about saw miter degree scales.
    -rick
  16. Pav8427
    Pav8427
    Anyone notice one side is 0-90 degrees and other side is -15-75 degrees.
  17. Dave Gray
    Dave Gray
    I did not notice that until you pointed that out. Non-auto related is starting to make more sense
  18. RodStRace
    RodStRace
    Agreed, especially if used as a transit/***tant. Set up the 90 side with a level, use the other side to find angle.
  19. ClayMart
    ClayMart
    Looks like it's made of br*** or bronze which gives it the appearance of some sort of nautical or navigational usage. Being non-magnetic may have allowed it to be used around comp***es or other sensitive sensors or gauges.
    Just Gary and Budget36 like this.
  20. distributorguy
    distributorguy
    from MN
    Its a vintage radio dial. Not distributor or engine related.
  21. ClayMart
    ClayMart
    Hmmm . . . Directional radio antenna?
    o_O
  22. G-son
    G-son
    from Sweden
    Whatever it is, the wear implies it has seen a lot of use, one way or another.
  23. lostone
    lostone
    from kansas
    I'm with the not distrutor related camp.
    It's for reading angles not engine degrees is what I'm betting on myself...
  24. Dave Gray
    Dave Gray
    Whatever it is, it must be very obscure. A bunch of very seasoned guys have looked at this thing and no one has identified it yet. I sure don’t have a clue. Yet..
  25. Pav8427
    Pav8427
    ClayMart likes this.
  26. Dave Gray
    Dave Gray
    The last post is as close as I have seen, but still not the same part.
  27. distributorguy
    distributorguy
    from MN
  28. patsurf
    patsurf
