Hot Rods Help identifying wheels
Discussion in 'The Hokey Ass Message Board' started by bantam, Jan 27, 2026 at 6:37 AM.
  1. bantam
    bantam
    Hi -
    Appreciate any ***istance identifying these wheels.
    thanks
    Bantam
    Greenblade likes this.
  2. Carter
    Carter
    Model A Ford cut down to 16"
    34 GAZ, RMR&C and flyin-t like this.
  3. bantam
    bantam
    Ah, right, I was super confused about the Model A appearance but the 16” diameter.
    Common practice back in the day?
  4. Carter
    Carter
    Yes indeed! Leading up to,, during, and immediately after WWII, 16" tires were by far the most common size and hence were plentiful used.
    302GMC and rattlecanrods like this.
  5. rusty valley
    rusty valley
    I've seen quite a few of those. Some done so good you could hardly tell they were home made.
    Carter and Squablow like this.
  6. I had a full set of these on a Model A recently, and was, like you, perplexed with the origins.
    From what I learned, during WWII rubber rations were introduced and since a lot of vehicles were on 16" wheels by then, used 16" tires were plentiful. Many folks with Model A's cut the spokes off their 19" and 21" to fit a '35 16" wheel and scavenged for used tires. This kept them from having to swap to later brakes or get adapter rings to run the later wheels on their A's.
    Stan Back, Greenblade and Carter like this.
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  8. alchemy
    alchemy
    Maybe not.
