Technical Help ID'ing this sweet Ford Axle (V8-60) Hubs?
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Jan 30, 2025.
  1. '52 F-3
    '52 F-3
    from Central PA
    Picked up this beautiful Axle a couple weeks ago at a Swapmeet, for an upcoming project. First, it's in great condition, whomever redid kingpins and wheel bearings did a great job.
    So I think it's a 1937 V8-60 with 42-46 Square back spindles (except the p***enger side only has one tie rod hole). and the "Wheel Hubs"? they are 5 on 5 1/2 but have odd bearing caps, that have the threads inside the hub.
    Any help appreciated.
    Thats a 46 axle in a few pictures for reference.
    20250118_071641.jpg 20250118_071737.jpg 20250118_071744.jpg 20250118_071836.jpg 20250130_154131.jpg 20250130_154143.jpg
  2. rusty valley
    rusty valley
    40 ford hubs
    AVater, '52 F-3 and Moriarity like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    AVater, '52 F-3 and rusty valley like this.
  4. Fordors
    Fordors
    I think they are ‘46-‘48. Didn’t the earlier hydraulic drums mount inside the hub?
    Upon further review it appears I have it backwards. Carry on.
    26 T Ford RPU, AVater and '52 F-3 like this.
  5. '52 F-3
    '52 F-3
    from Central PA
    It seems only 1940 used the screw-in grease caps and a unique 7/16" kingpin locking pin/steering stop. I turned down to fit.
  6. Fordors
    Fordors
    It was the so-called V8-60 tube axle that was different, not that later spindles are unique. The tube axle was introduced in ‘37, the spindles you have are ‘42-48’s, king pins for the V8-60 axle had a radius milled into them for round retainers and those were smaller (7/16”) diameter. To use regular’37-‘41, or the longer ‘42-‘48 king pins most guys drilled the axle for the 9/16” diameter wedge type retainers.
    '52 F-3 likes this.
  7. 41 Lincoln Brakes used screw on hub caps.
    '52 F-3 likes this.
