Help - Ignition Coil Questions???
Discussion in 'The Hokey Ass Message Board' started by mart3406, Jan 22, 2010.
  1. 350s15
    350s15
    OK, I have a aftermarket coil in it and was gonna get 20amp switches so I still should be fine correct?
  2. 350s15
    350s15
    Either way I read having the coil power on its own wire and not sharing with other components is better for coil life. Also every time I've had to do work where I needed my key switched to "on" I've always unplugged my coil so it wasn't drawing the whole time. And after reading what you where saying I'm glad I was doing that.
  3. RodTallman
    RodTallman
  4. RodTallman
    RodTallman
    I'm confused on this amp formula. Bubba used the example of a problem coil (.7 ohm coil with a 2 ohm resistor on a 12 volt) and said divide it, but came out with 32.5 amps, wouldn't it be 12 divided by 2.7 = 4.44amp ? You would multiply 2.7 x 12 to get 32.4 Am I all mixed up here?
    Truck64 likes this.
  5. LuisPacino
    LuisPacino
    Hi Bubba and friends! I have a Beru ZS106 coil. It gives 25.600v and has 3.3 omhs in the primary circuit. Non ballast resistor. My question is; Can I fit this coil with my traditional Dizzy (breaker points) without risk of burning something?
    Thank you!
  6. buick bill
    buick bill
    from yreka;ca
    so am i under thinking this whole thing if i just run the napa coil listed without a resistor on my 41 chevy with stock points dist., and 12 volt conversion . im not a big fan of resistors . i believed with a 12 v coil on points dist they werent needed . im not sure what i have for a coil now , but the car starts and runs good , but afterabout 5 mi starts to stall and miss and makes me wonder if ill make it home . seems as if the coil is over heating and i thought i might try installing a resistor and see if that fixed it . would prefer a new coil though if that would fix it. i dont think it matters ? but the stock mtr is actually a 62 235 with the stock points dist !!
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    you absolutely need a resistor with a 12 v system, your truck was originally 6 v and that is why it didn't need a resistor when new. what you need is a 1.5 ohm coil and a 1.5 ohm ballast resistor, then your points will last a good long time. without a resistor I bet the points will burn up in less than 50 miles
  8. Truck64
    Truck64
    from Ioway
    Don't guess!! Measure. A contact point ignition system requires about 3 ohms total resistance in the primary ignition circuit, this includes everything, the primary winding of the coil, the ignition switch, wiring, connectors, distributor to block, etc.
    That's the minimum ohms resistance that will limit the total current to a safe level on a continuous basis, or stuff starts roasting. What the OEMs also did, which often confuses people, was split that 3 ohms in half to 1.5 ohms using a divider network at the starter solenoid relay.
    This gives a bit hotter spark on a cold engine when the key is turned to start. When the key is turned to "run" and the engine is running then the extra ballast resistor was employed and voltage/current is reduced. Moriarty is right, the points will probably burn otherwise. Figure out what you have, measure, and Bob's Yer Uncle.
  9. 19Fordy
    19Fordy
    When I divide 12 by 2.7 I get a different number.
    12V divided by 2.7 OHMS yields 4.44 AMPS, NOT 32.4 AMPS.
