Help, Info Needed on Olds 303
Discussion in 'The Hokey Ass Message Board' started by The Breeze, Apr 18, 2008.
  1. The Breeze
    The Breeze
    I'm looking at buying an Olds 303 for my coupe. Is there any inherent problems with the 303 I should look for before purchace.
    Thanks
  2. yorgatron
    yorgatron
    good engine.
    the problem is what transmission.
    the hydro;durable,but expensive to rebuild.
    factory manual/vintage aftermarket;rare and expensive.
    modern manual/auto adaptor;expensive,but you can get overdrive 700R4 or T-5 and improve your gas mileage.
    i hope you have deep pockets.
  3. ocfab
    ocfab
    I'm $3000.00 in to one now and have not even opened it up to rebuild, It still need all the internals. I'm pulling the pin and going to sell every thing. if you are looking for parts PM me i have 2 6x2's setup's, bell housing adapter to a T-5 Starter swap, Oil re locater, flywheel ,starter, complete untuched 303, a set of 324 heads, Mickey Thompson stroker pistons ,Mallory dual piont dis. and so on.
    Let me know
  4. yorgatron
    yorgatron
    the Oldsmobile Rocket 8,it should come with a warning sticker that says "not for the faint of heart".
    you should change your sig line now.
    the only reason hop up parts are expensive for these is morons like you that start hoarding everything in sight.
    then 1st time you run into a problem you throw a SBC in your car.
    a lot of people want to call themselves "Rocketeer" but lack the grim determination to do so.
  5. kooldaddy-o
    kooldaddy-o
    pm'd ocfab for parts
  6. bumpybigblok
    bumpybigblok
    from Midwest
    Man , How times change. For my first A Hot Rod, I bought a 303 Olds with 6 2's and factory 3 spd. for $35.00. They say there's no inflation, but I'm starting to not believe it. Oh Yah, it was May 63
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    Bought a good running 51 Olds in 61 for $80. Used everything but the oink in my first roadster. Big thing I remember about them was noisy lifters as with a lot of miles the lifters didn't get enough oil. Still ran damm good though.
  8. touchdowntodd
    touchdowntodd
    only issue i had with mine is the valve seals go bad after a few years... shorter if sitting..
    gotta do mine, but its not that bad... just needs redone
  9. touchdowntodd
    touchdowntodd
    hey WTF... ocfab copied my sig exactly? ive had this one for years now? i guess its gay to get mad but thats just odd..
    i feel like you owe me amn intake outta that! ;0)
  10. Damn right!
  11. Paul
    Paul
    Editor
    want ads in signature lines are gay
  12. touchdowntodd
    touchdowntodd
    might be gay but ive gotten some nice parts off of it... and GOOD deals..
  13. Paul
    Paul
    Editor
    still offensive
  14. d2_willys
    d2_willys
    from Kansas
    got the original 303 in my '50 98 and runs pretty damn good for 58 years old. Lifter once in awhile starts to click a little but other than that, very strong.
    All of the 303,324,371, and 394 Olds engines are strong. If you decide to build an Olds engine you may want to go with the 59/60 371's or the 59-64 394's.
    SBC's are everywhere, but Rockets are forever! Dual Range Hydro's too!
