1952-59 Ford help installing stainless clips on a 55 customline
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Mar 23, 2016.
  1. BeerMoney
    BeerMoney
    well people i need help again i just got a new set of moulding clips for my 55 customline the problum is the clips just fall out when i put them on they are real lose
    any help will be very much appreciated. i had old spring type clips before but a want to go back to the original clips when i get it back from the paint shop
    thanks
    BeerMoney (aka| Bobby
  2. Paul Selfe
    Paul Selfe
    Bobby, If you have some of the Dum Dum putty, (looks like grey modeling clay) stick a little ball of it on each side of the clips to anchor them into position on the moulding. Once the mouldings are in place you can remnove any excess that squeezes out. Paul Selfe.
  3. bobss396
    bobss396
    Post a picture of the clips and the holes it goes into. I have some of the old clips from my Ford and it looks like there is some red hard sealer that helped hold the clips or made it water tight.
  4. mikhett
    mikhett
    from jackson nj
    When I restored my 62 galaxie i bought "REPRO" clips from Carpenters > I spent 55.00 and they would fall out of the hole.I got spring wire type clips from" Restoration Specialties".They have been on for 9 years now!
  5. Texas57
    Texas57
    Aside from the falling off problem, when you do get to ***embly, put a ring of caulking around each stud before attaching to the car. You need to get a non hardening sealer on those or they will leak. 3M caulking strips are perfect for it because of the smaller diameter of the strips, but a good household variety may be easier to find. Many body supply/paint supply shops carry the 3m strips.
    If the clips you're talking about are the little propeller shaped ones, make sure you load them on to the strip the correct way. They should be on there so when you tighten the nuts, it turns the clip tight against the moulding, not so they want to loosen/turn out/away from the moulding when you tighten the nuts.
  6. 55Brodie
    55Brodie
    Bobby, it is hard to explain, but you have to spread one of the 2 tangs that go into the sheet metal hole. Start by making sure all the clips are oriented the same...I think there are about 20 per side. Insert the clip and while holding it in place, take a pair of pliers and grab the tab in the center and gently bend it in one direction. This should spread the two tangs and firmly hold the clip in place. With practice it becomes easy. Make sure you have the correct clips. I used B21066-1 from T-Bird Products. Get a few extra as you will probably destroy some.
  7. 55Brodie
    55Brodie
    Oh, and there are only 2 stud with nut type retainers per side; the very front and rearmost positions. All others are the clips noted above. The stainless snaps over those.
  8. bobss396
    bobss396
    I'll shoot some pictures of my clips. Like 55Brodie says, you have to spread the tangs in some of them. Probably the ones that go in the square holes if you have those.
  9. 54vicky
    54vicky
    if you look up DC under fasteners he lists the tool for the clips.when I put mine on over 30 years ago I made do with a pair of pliers I ground down.once you see it you can do as I did
  10. bobss396
    bobss396
  11. BeerMoney
    BeerMoney
    thanks
    55Brodie
    i did what you said and it works great fits really tight. yes i got mine from t-bird also same part number B21066-1
    thanks for the info and help. i thought for sure they sent me the wrong clips.
  12. BeerMoney
    BeerMoney
  13. BeerMoney
    BeerMoney
    ok great
  14. 55Brodie
    55Brodie
    Clips fit round holes too IIRC.
