Technical Help. Jacking up car
Discussion in 'The Hokey Ass Message Board' started by TheBookman, Jul 14, 2022.
  1. TheBookman
    TheBookman
    Hello fellow hot rodders,
    I apologize in advance for this silly question, I am new to the scene.
    Trying to figure out the best way to jack the front end up for stands. I was thinking about in the middle of axle? Should I be worried about the leaf spring? I have attached a photo to show you what I am dealing with.
    Any thoughts or suggestions would be greatly appreciated.
    Cheers.
  2. manyolcars
    manyolcars
    sure. jack in the middle but NEVER pull from the middle
    seb fontana likes this.
  3. 56don
    56don
    Done it that way numerous times.
    lothiandon1940 likes this.
  4. TheBookman
    TheBookman
    Thank you for the information
    lothiandon1940 and Just Gary like this.
  5. TheBookman
    TheBookman
    Good to know, thank you.
  6. ModelAMitch
    ModelAMitch
    Centre of the axle, stands on either side. Letter rip
  7. squirrel
    And you want to buy a full size floor jack, too....
    X-cpe, TA DAD, bobss396 and 3 others like this.
  8. belair
    belair
    Never be afraid to ask...
    210superair, raaf and squirrel like this.
  9. raaf
    raaf
    ...and while obvious to many, a little block of wood in the middle distributes the weight a bit too.
  10. kabinenroller
    kabinenroller
    My car is low, I built a set of wood ramps that raise the front about 3”, the ramps are at a slight angle so it is easy to drive on them. Once the car is on the ramps it is easy to use a rolling floor jack to raise the car and install the jack stands. I also always use rubber wheel chocks on both rear wheels to prevent the car from moving until the jack stands are in place.
    Safety is no accident.
  11. raaf
    raaf
    Yes @kabinenroller is saying something no one mentioned. Use wheel chocks - that's an important part.
    lothiandon1940 and 41rodderz like this.
  12. 41rodderz
    41rodderz
    from Oregon
    I know of two people that got crushed by not doing the right thing. One used cinder blocks and died at 18 years old. Number two decide he didn’t need wheel chocks and died at 70ish.
  13. I allways tuck the stands in against the wishbone ends so they can,t slip on the curve of the axle.
  14. clem
    clem
    ^^^^^ this - you bet me to it.
    Careful using a block of wood, 2 more points of contact- a flat piece is better - and it can easily roll either way if too small.
  15. clem
    clem
    only if the shape of the wood matches the curve of the axle.
  16. lothiandon1940
    lothiandon1940
    Like Jim said, get a bigger floor jack. There's a lot of weight there on that front end. Careful.
    hrm2k and Just Gary like this.
  17. ^^^^ and^^^^ make sure the floor jack has enough travel to allow room to get the stands under the axle.
  18. bobss396
    bobss396
    I've been using ramps lately too. Drive the car up, chock the rear wheels and then raise it with a floor jack... work like a gentleman.
  19. i.rant
    i.rant
    rod1, olscrounger, 302GMC and 3 others like this.
  20. lothiandon1940
    lothiandon1940
    ^^^^Excellent^^^^
  21. ekimneirbo
    ekimneirbo
    One other thing to consider is "how high" you plan on raising the vehicle......and I'm sure that height will vary with what you are trying to do. If you jack it vry high, you need to go part way and set it on jack stands. Then raise the rear and set it on stands. Then back to the front and take it a little higher and adjust the stands.
    For some simple tasks where you don't need to get under the car, its ok to jack it up at one end so its on an angle. If you are going to crawl under it, its best to keep it level.
    Never use concrete blocks to set stands or the vehicle on.
    You can roll some mounted spare tires under raised vehicles so if they do fall, the vehicle will land on them and not crush you.
    Last thing is to always be on level ground so the car doesn't try to roll. If you jack the rear wheels up, there is nothing keeping the vehicle from rolling.
    Thats everything that I can think of............:)
  22. Cree
    Cree
    from Montana
    A floor jack arm on tends to pull the car toward it as it rises. When jacking the front, the rear wheels must roll forward so I ensure an automatic trans is in Neutral so to not stress the Park pawl. Then chock the rear and place stands.
    Almostdone likes this.
  23. kabinenroller
    kabinenroller
    I mentioned the ramps I use to raise the car slightly so that a conventional floor jack can be used to lift the car to the desired height. I forgot to add that I glued some soft rubber to the bottom of the ramps so they do not slide when the front wheels begin to rise on the ramps.
    Also, jack stands are good but sometimes they are in the way when working under the car. If the car has tires mounted I prefer to support the car by wood structures under the tires. I have found that a 12” rise is a good working height. Mine are made using 4x4’s, I am sure they are stout enough to support more weight than I expose them to with my car.
    34 GAZ, SlamIam, old chevy and 4 others like this.
  24. Almostdone
    Almostdone
    If there was a ‘damn!’ ****on I would have pushed it, but ‘Like’ just didn’t seem to fit.
    John
    clem likes this.
  25. adam401
    adam401
    Im pleased with all the positive responses in this thread. Thats how the hobby thrives. Better to ask a question than get hurt or killed.
    clem and Just Gary like this.
  26. TheBookman
    TheBookman
    I appreciate all the great help and words of wisdom everyone. New floor jack has been ordered, and I have some old 2x4 being cut down to size. Many thanks
    Just Gary likes this.
  27. 51504bat
    51504bat
  28. choptop40
    choptop40
    I alway use blocking before I get under a car…if you don’t have anything use the spare tire ..yes we had a auto shop teacher in Long Island found crushed under his Jaguar…a shop teacher no less.. tragic.
