Hot Rods HELP: lowered problems
Discussion in 'The Hokey Ass Message Board' started by Doctorterry, Sep 22, 2015.
  1. Doctorterry
    Doctorterry
    So I'm sure I'm not alone on this problem, but in my lowered '62 biscayne when I hot rod it, or when I have a carload of p***engers, my drive shaft or rear end or something clunks hard against my floor.. What can I do to solve this? It has coils all around.
  2. 57 Fargo
    57 Fargo
    Simple, un-lower it or stiffer springs, or cut and rebuild the floor for clearance
  3. David Gersic
    David Gersic
    from DeKalb, IL
    Bump stops so it can't bottom out on the drive shaft. Stiffer springs, maybe progressive so they don't ride too harsh when empty.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If Female, pics are needed for best advise ;)
  5. Kerrynzl
    Kerrynzl
    Please no! Not if they are bottoming out the suspension.
    These things cannot be unseen!
  6. slammed
    slammed
    Monroe overload/coil over shocks will help. Did you cut 2 wraps or use 4" coils back there? An air shock can work, but is a stiffer ride when inflated beyond 75%. PIX!
  7. 57 Fargo
    57 Fargo
    I'm not super familiar with those cars but keep in mind some shock mounts can't handle carrying weight, such as using air shock or the shocks with the helper springs.
  8. aaggie
    aaggie
    When you build/change/design suspension systems you need to have the car frame sitting on jack stands and without springs or shocks installed , run the front and rear through it's full travel to see where it hits. Now you know where to notch frames or make mounts. Your Chevy is an "X" frame with the driveshaft running through the center cross member so it is more difficult to work with. Solid bump stops between the rear axle and frame along with stiff springs or air ride will be your best bet.
  9. Gman0046
    Gman0046
    My 64 Biscayne has 2" drop spindles and short coils in the rear and rides really well. I think the stance is perfect. With a load of six and a trunk full of bags I also have a driveshaft problem. Being as this is the only time I have problems and rarely happens, I'm not about to change anything. I just won't load it down any more. Just an inherent problem when lowering X frames.
    Gary
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now hold on, take a look at Slammed's avatar on post #6. The number of Females is equal to the amount of volume per unit.
  11. Jimmy2car
    Jimmy2car
    from No. Cal
    I'm with Johnny Gee
  12. Jalopy Joker
    Jalopy Joker
    post some pics - so, how was the car lowered? how low in front/rear? have you been underneath to see where something is rubbing/hitting? condition of driveshaft support bearing? shocks are not the total answer to the problem with lowered rear coil springs - need more details
  13. Mr48chev
    Two simple solutions might be a pair of overload air bags like they run on a lot of pickups that don't come into play until you load the vehicle to a certain point or a pair of overload coil springs that do the same thing. I'm not sure either will work with that suspension though. I had a pair of the springs on my 48 pickup when I was towing and used a pair on my 51 Merc when I was traveling or towing.
    The other alternative is to reshape the driveshaft tunnel where it is rubbing.
  14. Doctorterry
    Doctorterry
    Let me go snap some pictures... I can't really see any place that looks to have been hit. My dad claims that it is hitting at the rear end. He says when you goose it, the back of the car squats, and the rear end will rotate up/forward thus the two coming in contact
  15. Doctorterry
    Doctorterry
    ImageUploadedByH.A.M.B.1443039092.550731.jpg ImageUploadedByH.A.M.B.1443039103.323942.jpg ImageUploadedByH.A.M.B.1443039131.085711.jpg
    It was worthless to upload these pictures, I'll have to get it off the ground and take some. We just cut coils to drop it ImageUploadedByH.A.M.B.1443039197.103874.jpg
  16. dirtracer06
    dirtracer06
    On my 63 the drive shaft would bump the the tunnel. I added air shocks, I only added air as needed when I was hauling something or a bunch of people. I hadn't cut anything off the springs it was lowered with the help of age....
  17. Kerrynzl
    Kerrynzl
    Haha!
    You're lucky Slammed's avatar on post #6 chimed in after my reply on post #5 ,to your comments on on post #4
    Incredible predicting skills [ a good save ]
    Johnny Gee likes this.
  18. Jalopy Joker
    Jalopy Joker
    what did you use to cut springs? cutting rear coils different than cutting fronts - the way the coils are wound - looks like coil in pictures is ***led, maybe not seated properly.
  19. Doctorterry
    Doctorterry
    Cut with a cut off wheel if I remember right
  20. flyin54
    flyin54
    from modesto ca
    Probably driveshaft hitting rear of frame tunnel, need to raise rear or don't load as heavy, maybe trim frame at rear of tunnel a bit to give you some room.
  21. Doctorterry
    Doctorterry
    Do they make traction bars for coils? Wouldn't that solve the problem?
  22. slammed
    slammed
    How many wraps of the coil were cut? And did you go w/a shorter (2" coil drop need's a 2"shorter shock that is Gas charged like a Monroe Sense-a-trac minimum.
  23. Kerrynzl
    Kerrynzl
    They do! They're called links [as in triangulated 4 links]
    hipster likes this.
  24. surfcaliforniasurf
    surfcaliforniasurf
    As a 59 owner I may know your problem and have a easier solution that will also save you other headaches. When I let the air out of my bags my stock rear driveshaft would rub on the very back of the floor so I never drove with bags all the way down. I was also having a problem with my carrier bearing blowing out every 2000 miles from the suspension travel. I bought a telescopic rear driveshaft from ****'s Drive Shaft in Arizona to save my carrier bearing, and when it arrived I realized it had a slightly smaller diameter than the stock rear driveshaft. After installing it I have driven over 20,000 miles with no carrier bearing problems and no more rubbing of the drive shaft on Full deflation. Since I am not out drag racing the smaller diameter rear shaft and telescopic section don't bother me. I can't promise this will help your problem but it worked for me!
    Doctorterry likes this.
  25. nwbhotrod
    nwbhotrod
    from wash state
    what he said is dead on and you may need a adjustable panard bar to center your rear end check your upper control arm bushings
  26. Doctorterry
    Doctorterry
    Sweet... So is the only difference in the microscopic drive shaft that it is smaller in diameter?
  27. surfcaliforniasurf
    surfcaliforniasurf
  28. Doctorterry
    Doctorterry
    Awesome. So you just purchased the rear piece? And used the stock carrier bearing or bought the one they offer? Is this what you suggest?
  29. surfcaliforniasurf
    surfcaliforniasurf
    I used a stock cheapo from auto-zone. Yes I bought rear portion. Most x frame drivers that have adjustable suspension run the teacopic rear section.
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I was always on the path of enjoyment for all, not the other way around. :)
