Hot Rods Help me decide 36' Ford P/u
Discussion in 'The Hokey Ass Message Board' started by DirtyWoody28, Dec 6, 2009.
  1. DirtyWoody28
    DirtyWoody28
    Should I do my 36 with fenders, or without fenders and a bobbed bed? My only problem with doing it with fenders is that the ones I have are gl*** and I don't have the original frame. I believe all Fords 36-39 have almost the same frame so I would have to find one to match.
  2. rust&patina
    rust&patina
    both of these trucks look *****en...but i like em with fenders...i think 35 to 40 frames are all the same...
  3. robert56
    robert56
    Go with the fenders. These trucks have some of the best styling cues ever on a truck, but many of them are lost without the rest of the sheetmetal.
    And I used a frame from a '40 coupe when I built my '36 Ford truck. It was a direct swap as far as I could tell. Everything bolted right up.
  4. DirtyWoody28
    DirtyWoody28
    i'm putting a 283 in it
  5. hotrod-Linkin
    hotrod-Linkin
  6. Carbs & Chrome
    Carbs & Chrome
    fenders - start a trend :D
  7. DRUGASM
    DRUGASM
  8. DirtyWoody28
    DirtyWoody28
    thanks guys, so does anyone have a ch***is? lol
  9. Thorkle Rod
    Thorkle Rod
    If you aren't going to use the fenders I buy them from you
  10. ironandsteele
    ironandsteele
    fenders without a doubt. no question about it.
  11. DirtyWoody28
    DirtyWoody28
    how hard is it to find steel ones if I ever decide to switch out the gl***
  12. hvychvy
    hvychvy
    Fenders for shure!!!I'm shure it would be a pretty good chore to find some decent steel ones though.
  13. Shane Spencer
    Shane Spencer
    Ill have to say fenders. Although if you took the other pic and moved the front axle back a lil under the truck and didn't bob the bed quite as much it would look freakin sick too. Good luck :D
  14. solid
    solid
    35-40 car and truck, and 41 truck are close to the same. I say with fenders..
  15. Justin B
    Justin B
    put the fenders on it, frames are easy enough to find. if you were closer i know where there's a few out here cheap. steel fenders on the other hand are a little hard to find.
  16. hotrod40coupe
    hotrod40coupe
    Run it with fenders.
  17. chopped 35
    chopped 35
    from australia
    i'm going for fenders/guards on mine.......... if i ever get around to it:D:D:D
