help me design a motor 327, what cam??
Discussion in 'The Hokey Ass Message Board' started by murf-lostincity, May 10, 2009.
  1. murf-lostincity
    murf-lostincity
    i have a 54 chevy m2 up front, bags in the rear
    700r4 w/stage2 kit
    this car is going to get some serious miles i am building it for a daily driver but i will also like to have some fun and haul some *** once in a while
    here it goes i have a 327 with camel hump heads and a set of ramhorn exhaust , and this cam i bought a while ago https://shop.enginekits.com/osb/itemdetails.cfm?ID=103
    is this going to give me some good power while not idling to bad?
    or is it safe to bump it up a bit and maybe get a bigger cam??
    i will eventually run tri-power
    i wouldnt mind idling like this, what cam u guys think he has??
    http://www.youtube.com/watch?v=YIaEqN_FHy0&feature=quicklist
  2. murf-lostincity
    murf-lostincity
  3. skunx1964
    skunx1964
    that cam will prolly sound pretty decent and work well for a driver car. not too wild or racy, just a good street cam
  4. SteelerDan43
    SteelerDan43
    Well I would suggest playing with one of the Performance Trends Engine ****yzer programs (they have free demos). From the small amount I've learned a couple rules or thumb are larger lobe separation = smoother idle (>110 for good idle street car), longer duration = more power but rougher idle... I am by no means an expert on cam profiles but I would venture to say that yours should do the trick.
  5. vncruiser
    vncruiser
    I would go with the Elgin cam <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD>[FONT=Verdana,Helvetica, Arial, tahoma]E903P[/FONT]</TD></TR><TR><TD>[FONT=Verdana,Helvetica, Arial, tahoma]Elgin .447/.447 Lift - 222°/222° @ .050 It is the same as the 327/350 hp cam from the 60's. Has a slight lope at idle and properly tuned will get you decent mileage on the highway, and a nice kick in the pants around town. Used the same spec cam in my son's 61 Chev p/u with 600 holley, Weiand manifold and headers, turbo 350 trans and 3:55 gears. Made for a fun and reliable ride with a lot of get up and go....[/FONT]</TD></TR></TBODY></TABLE>
  6. Baumi
    Baumi
    Hi there... I love 327! I have one in my 56 chevy. I just love the sound, the quick response performance, and the never ending power band, it revs like there´s no tomorrow, haha.
    It´s got Speed Pro L2166 NF 030 Pop ups, 2.02 Camel Humps, a 234°/244°@.050 cam ( which is a Edelbrock Performer RPM) also Performer RPM intake manifold and 600 cfm carb. Here´s a video, since then I changed the exhaust system for better ground clearance, but the sound´s still the same
    here´s the link.
    Chris
    http://www.youtube.com/watch?v=VdnTqDswIFY&feature=channel_page
  7. Baumi
    Baumi
    The engine was still could and was on choke, that´s why the idle is higher than usual.
  8. Xdrag48
    Xdrag48
    I have used a 4 x 4 offroad (RV) cam in my small block before,has a good sound and power range is idle to 5500 rpm's....
  9. Herdez
    Herdez
    The old performer rpm upper kit is great and very good on power sounds lopy too. Ive seen this in action in a 350 with camel humps on a very daily transportation 78 Elky. ran very fast! Elgin cams sells an indentical camshaft to the performer rpm cam for less money too.
    Sig erson had a good adv. 292h cam if theyre still around 214 duration .449 lift 110 nice idle,ran very well,had good power daily driver 3.08 gears stock stall 68 Elky in high school.
    Comps 275DEH was the cool thing too for street until the 268h extreme series came out. I think you can find articles about those cams all day long.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    The old 350Hp/327 cam ended up being the stock factory cam for many years until the EPA got involved in cars.
  11. murf-lostincity
    murf-lostincity
    I was thinkin about that e903p elgin 222/222@ .50 just a step p from what I got
    What do u think the HP difference would be
    214/224@.50. Vs. 222/222@.50
    I need to decide which one I these will do the trick
    Maybe the smaller one for slightly better mpg??
  12. blown green t
    blown green t
    Comp Cams 275 DEH, I'm running one in a '69 327 in my chevelle. Runs good, decent idle.
  13. murf-lostincity
    murf-lostincity
    Or mAybe the that 350/327 cam u guys are talking about
    The 222/222@.50 cam from the 60s
  14. Herdez
    Herdez
    split duration cam lobe seperation is probably around 112 or more
    222 222 is probably 110 rowdy hits harder
    214/224 is more power across the power band
  15. 327/350 cam sounds awesome! Just like a muscle car should, and it runs good!
  16. Larry T
    Larry T
    If it were me, I'd probably go with the cam you have now. The e903p (same specs as the 327/350hp "151" cam) is big enough that it is a little soggy feeling just off idle in a car with an automatic and is just a little tempermental to get to idle with a stock converter. You could go with a little higher than stock stall coverter and it would probably work fine, but then you could give up a little gas milage.
    Larry T
    BTW Herdez, I'm pretty sure the 222/222 cam is ground on 114 lobe seperation.
  17. murf-lostincity
    murf-lostincity
    I would like to get decent mpgs
    But I also want to get that kick in the pants feeling when I step into it..
    This is going to be a hard decision....
    If I did go with that e903p
    350hp/327 cam I was thinkin about getting a 2200-2400 stall converter
    Any guesses on mpg???
  18. x2cracing@msn.com
    x2cracing@msn.com
    the 327/350 that is recomended on here is a very good setup. the 67 vette stock setup ran strong. i liked the early vette 327/365 motor a bit better because with the solid lifter setup it had a 7000+ rpm red line and was very street friendly. IMO the best all around street/race motor to come out of detroit .
  19. Larry T
    Larry T
    No guesses on the milage, although I've seen older Corvettes get close to 20 on the highway.
    You might price a lockup torque converter before you make up your mind on which cam to run.
    Larry T
  20. death trap man
    death trap man
    from Atco NJ
    The cam you have will probably work well. If you are looking at new cams, check out the lanati Voodoo cams. I have one but haven't run it yet. I was in a similar situation and it has come highly recomended by a few guys that build engines localy. Nice wide power band. But the cam dose have to match the rest of your set up.
  21. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I picked up the save very cam at the Pate Swap meet the other day. Told the guy I was looking for something comparible to the 350/327 cam. Good to know thats just what I ended up with. Figure it was a good deal at $40 new.
  22. murf-lostincity
    murf-lostincity
    If I went with the e903p 222/222@.50 350hp/327
    Cam what what be the best stall to go with on a torque converter?
  23. buffaloracer
    buffaloracer
    from kansas
    I think you will be happy with the cam you have. The 350hp cam or the old 140 trans-am cam are not a lot of fun with an automatic in an everyday driver.
  24. V4F
    V4F
    from middle ca.
    i would use a ... 30/30 duntov . if not a 350/327 cam .................. steve
  25. Herdez
    Herdez
    The e903p is a great cam I just got the site to come up to see the specs and yes thats the same cam my 283 had before this last rebuild and a 30/30 in its place now. Great cam slight lobe very very street friendly motor ran 10 years strong daily driven.
  26. Retro Jim
    Retro Jim
    I really think you will be very happy with the E903P cam . You will get good torque and that hot rod sound at idle . I will also be easy on the valve train too !
    Let us know what you decide .
  27. 42hotrod
    42hotrod
    from S.E. Idaho
    Thats my favorite 327 grind. I've had of them they even run good in a 350.
  28. kgriff
    kgriff
    from CA
    For a daily driver with ramshorn exhaust, I think you'll be happy with the cam you have.
  29. BMR
    BMR
    from ill.
    have you ever heard about a 4 7 swap?
  30. murf-lostincity
    murf-lostincity
    well it looks like I have my motor figured out
    The one I was going to buy fell thru but I just found a guy selling this motor
    I just picked up a
    327 .30 over block fully detailed casting removed and smothed down
    Original crank
    New pistons
    New eagle rods
    New pushrods
    Freshly rebuilt camel hump heads
    New oil pan
    New e903p 222/222.50 350hp/327 cam
    New master rebuild kit
    All for $850 not bad huh?
