Help me ID my nailhead
Discussion in 'The Hokey Ass Message Board' started by Thomas B, Oct 13, 2005.
  1. Thomas B
    Thomas B
    from WI
    Deleted
  2. Kustm52
    Kustm52
    You can measure the distance across the two front intake manifold bolts..but I forgot the measurements. 322 is the narrowest, followed by 364, then 401/425. But now that I think about it, the 264 and 322 may be the same..oh well. I can measure a 322 for you later if no one has a better idea..
    Brian
  3. trey
    trey
    if it has an intake, post the casting numbers from it.
    trey
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    2 bbl or 4 bbl will probably help too its either a 322 or 264
  5. joeycarpunk
    joeycarpunk
    from MN,USA
    Off the top of my head 364's intake bolts are 8 3/4" apart and 401's 9 1/4" apart.
  6. 264-322 8 1/4" across the front intake bolts
    364 is 8 3/4
    401-425 is 9"
  7. trey
    trey
    according to my book, should be 264/322. correct me if im wrong.
    trey
  8. leadsleadolds
    leadsleadolds
    www.buicks.net
    all the info you need will be in there
    55 specials had a 264 the rest 322
    Unless its been swaped through the years
  9. TP
    TP
    from conroe tx
    It's a 55 322 4 barrel. TP
