Technical help me id this banjo rear end
Discussion in 'Traditional Hot Rods' started by azratrod, Dec 19, 2013.
  1. azratrod
    azratrod
    from Az
    is this a early ('35-41) or late ('42-48) 40's era ford banjo rear end? I know the older ones are slightly wider. I just don't have a reference to go by. thanks
  2. Carter
    Carter
    Looks like a 42-48.
  3. kb cookout
    kb cookout
    1942 -48 has the short radius rods like this one
    later kb
  4. aonemarine
    aonemarine
    from Delaware
    Thought the older ones were narrower..
  5. olskool34
    olskool34
    The shock mounts tell me later like said above.
  6. TERPU
    TERPU
    Yep '48 shock mounts. Don't throw them away.
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    The shock mounts will fit any rearend, but this IS a 42-48 rearend as evidenced by the short radius rods, and the rear Panhard bar mount on the drivers side spring mount.
    The earlier rearends do not have Panhard bars as the sprngs are mounted in tension as they were since 1909. The 42-48 rears had rubber bushed spring shackles and the springs were not under tension to give a softer ride to compete with the dual spring more modern GM and Mopar cars.
  8. azratrod
    azratrod
    from Az
    Thanks for the help guys!
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    measure the distance between the back side of the backing plate to the other side...'35-'41 is 51" and '42-'48 is 53"... btw, those backing plates are '39-'41.
    kidcampbell71 likes this.
  10. Randy P
    Randy P
    from Austin, TX
    I zoomed in on the picture and it looks like it has the little "spike" that points down from the outside edge of the spring hanger. That little spike is commonly considered 1941 only. However, I bought a rear once that had the spike, assuming it was 1941, but upon getting it home and measuring it found that it was the width of 1942-48. It also had the short radius rods. So, apparently Ford used up some of the "1941" ends on the new, wider 1942-48 axle housings. It's going to come down to the overall width or the length of the axle housings. In addition to the helpful information that has already been provided, this is a very helpful article:
    http://www.flatheadv8.org/fordrear.htm
  11. azratrod
    azratrod
    from Az
    I measured from backing plate to backing plate and it measured 51.00"-51.50". depending on if it was off the backing plate or the backing plates lip.
    but I thought the '42-'48 radius arms were the shorter ones versus the '35-'41?
  12. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    35-40 radius rods are the longer ones, And what skidmarks says is right, That is a 41 axle,......
