Hot Rods Help me ID this speed equipment!
Discussion in 'The Hokey Ass Message Board' started by Pinstriper40, Dec 16, 2013.
  1. Pinstriper40
    Pinstriper40
    It looks like it bolts to a regular 4 barrel intake, uses a generator to create more airflow, and has the word "Dragster" cast into the blower part. Who made it? When? Thanks in advance!
    Speed Gems likes this.
  2. Pinstriper40
    Pinstriper40
    I forgot the top picture.
  3. hugh m
    hugh m
    from ct.
    Looks like somebody spent a lot of time on that, but i can't tell just what it 's supposed to do given what's there...does all the air go through that radial blede fan?
  4. 30tudor
    30tudor
    At first glance it appears to be an electric supercharger. Novel idea.
    In fact do a search for 'dragster electric supercharger' and you'll be in the house.
    Google is your friend.
  5. hugh m
    hugh m
    from ct.
    How many RPM's can that thing develop? Most centrifugal superchargers are real screamers, not to mention the airflow thru that sideways hole. Pretty interesting find though, and a real investment to cast it up. An accomplishment for sure even if it doesn't work.
  6. Pinstriper40
    Pinstriper40
    It appears to be from the late 50's or early 60's. No idea on RPMs. It must've been a limited run and obviously didn't catch on.
  7. seb fontana
    seb fontana
    from ct
    What I know/remember..A starter motor, of that area would rpm 2500 give or take cranking an engine, going by 120rpm as cranking rpm...About 2hp and rpm is only limited by load or amount of current which if enough the motor will just rpm till it blows up..I actually saw a set up at a swap meet around 70'..Motor was vertical [no angle drive] and I believe a couple of 2v carbs, smaller overall not as ambitious as pictured one......Pretty sure there was a magazine there with it containing an article on the unit...And they are still being made for OT just as tinker-toy junk...
  8. saltflats
    saltflats
    from Missouri
    The fan reminds me of the cooling fan on my old air vair.
  9. Thats not a supercharger, but appears to be a way to atomize the fuel air mixture.
  10. seb fontana
    seb fontana
    from ct
    That maybe its only feature but probably not the intent..
  11. seb fontana
    seb fontana
    from ct
  12. tb33anda3rd
    tb33anda3rd
    back in high school shop cl***, one of my fellow students had rigged a heater blower fan to his carb using a large coffee can and some duct work. he would hit the switch and the motor would increase in rpm's.....but that was it.
    i always wondered if it was done right if an electric supercharger would work.
  13. summersshow
    summersshow
    from NC
    When I was in college we hooked a leaf blower on to an intake... gave the car like 80hp...
    That thing is neat, put it on and see what happens...
  14. RichFox
    RichFox
    Turbonic or something like that. They made rocket powered blowers pretty much the same as the electric one you have. Also the rocket powered third member. Do a search.
  15. Clark
    Clark
    Oberhausen...or something like that. It was advertised in hot rod magazines around 55 or 56
    I think they we're sold in kit form.....we had one and mounted it on a y block. Never tried running it. Doubt it would do anything. There should be a flap inside to block the p***age when the blower is in use.
    There have been a few posts on them
    Clark
  16. 303racer
    303racer
    x2 Oberhausen
  17. ziegld1
    ziegld1
    from St Louis
  18. ziegld1
    ziegld1
    from St Louis
    I'm doing research on this type supercharger. What I was told is that it was made by Dragmaster Co. on Peachtree in Atlanta, GA. But I have not found anything on this blower. Another fellow said he had one and had a Ford Starter motor. He also said he had a copy of an ad for this , but has not got back to me.
  19. Clark
    Clark
    55/56 hot rod magazines had a full page add for them.
  20. arkiehotrods
    arkiehotrods
