Help me identify this dash !?
Discussion in 'The Hokey Ass Message Board' started by Vincent, Oct 5, 2008.
  1. Vincent
    Vincent
    from Sweden
    Hi
    Ive been offered to buy this dashboard for my model A hot rod project for about 20-30 dollars.I really like it and i´ll probably buy it no mather where it comes from but it would be fun to now what car it´s originaly are from.Anybody knows??According to the seller its a dashboard from a -27 Auburn but i don´t agree with him.It´s about 150 centimeters wide.
    /Vincent
  2. Bruce Lancaster
    Bruce Lancaster
    Is the brown primer or rust??? That sure looks like a fiberglass streetrod dash with slightly miniaturized molded copy of Auburn panel...
    If it is real anything, it should have some holes for instruments...and the crude notch looks like the material is very thick...
    It it is what I think, it is a recent part made for Model rods. The crusty finish looks like old metal, but everything else seems to indicate glass, and your description seems to imply it is thought to be old.
  3. skidsteer
    skidsteer
    Here's a picture of a '26 Auburn roadster, doesn't look anything like it.
  4. tommy
    tommy
    That is a fiberglass streetrod part. If the gray is the original gel coat then it probably is an AI (Anderson Industries) piece. I think they made a dash with the smaller Auburn-ish style insert.
  5. alchemy
    alchemy
    Probably meant to fit into a 26-27 Ford T roadster body.
  6. Tommy's correct. We did produce a modified '27 roadster dash with a shorter styled Auburn cluster because a stock sized one was thought to eat up too much leg room in a roadster that didn't have much to spare.
  7. Vincent
    Vincent
    from Sweden
    Youre guys are right,ive talked with the seller and he confirmed that it´s a fiberglass dashboard so i´m not intrested in it anymore.
