Technical Help me identify this front end
Discussion in 'Traditional Hot Rods' started by Jalopy chris, Sep 17, 2023.
  1. Jalopy chris
    Jalopy chris
    Hi all, I’m starting a rat rod t-bucket project and I could use some help. Can anyone identify this front end I have? I don’t have all the parts and need some direction so I can replace what is missing.
    Backing plate hole pattern is 2.50” x 2.50”, and are a little bigger than .375” in diameter
    Spindle length is 4.25” from top of the round part to the top of the spindle, 5” in total from backing plate mount to end of spindle
    any help would be greatly appreciated
  2. Jalopy chris
    Jalopy chris
    Sorry, I guess what’s most important at this point is to figure out what the brake backing plate, and or spindle origins are
  3. Fordors
    Fordors
    Not 100% positive but I think you have early Econoline spindles and brakes, like ‘61-‘63. Those steering arms are homemade to adapt the r&p steering. Be advised that r&p is a non-issue here, it doesn’t fit the theme that the HAMB follows. Regardless, I see no way for a rack to work with a straight axle, take it off and go with a conventional worm and sector steering box. Oh, and your tube front axle could have been made by any number of early hot rod parts suppliers.
    caprockfabshop and Jalopy chris like this.
  4. seb fontana
    seb fontana
    from ct
    MAS is my guess for axle.
    Jalopy chris likes this.
  5. saltracer219
    saltracer219
    The R*t word is not spoken here, we are traditional pre 1965 Hot Rodders on this site. Please keep it pre 65 Hot Rods and Customs. Also it would be to your benefit to do an introduction.
    '28phonebooth and Jalopy chris like this.
  6. manyolcars
    manyolcars
    in case you didnt get saltracers message-- no rat rods!
    Jalopy chris and Budget36 like this.
  7. 51504bat
    51504bat
    65 and earlier not pre 64
  8. Budget36
    Budget36
    Hopefully it’s a generation thing that thinks Hotrods are rat rods. Give the fella a chance.
  9. blue 49
    blue 49
    from Iowa
    Tube axle should not use hairpins.
    Gary
    mgtstumpy, cal1320, Andy and 2 others like this.
  10. swade41
    swade41
    from Buffalo,NY
    There's thousands of t-buckets on the road with tube axles and hairpins, mine included
  11. Jalopy chris
    Jalopy chris
    Hey, thanks for all the responses. I’m really sorry for the mistakes I made with this post, I’m just not sure where else to go to information.
    Budget36 likes this.
  12. Jalopy chris
    Jalopy chris
    Sorry about this
  13. Jalopy chris
    Jalopy chris
    Thanks for the info, I’ll look into the econline dimensions.
  14. MAD MIKE
    MAD MIKE
    from 94577
    That pic is wild.
    Would love to see the steering shaft for that application. :D
  15. Mr48chev
    Only if the 65 is the same body design as a 64. = 65 Rivera works, 65 Nova works, 65 Impala doesn't work . If you can't tell it from a 63/64 or just a 64 without being an expert in the little nit picking year to year details life is good,
    Yuppers to the spindles being Econoline from the looks of this set on Ebay eBay item number:195881565003
    Popular spindle and brakes for tube axles in the 60's and 70's. eBay item number:195881565003
    The rack will "function" as far as steer the car but with those long steering arms it probably has a huge steering radius lock to lock. It adds a lot of unsprung weight to the the front end and looks **** ugly and is a lot of clutter on an axle that is supposed to be clean and simple.
  16. Edit your post to eliminate the 'rat rod' reference and you'll be OK here. Add your introduction and location so people can chime in from your local area if they have parts or can help you. Read and get familiar with the rules that apply to thread. Get yourself a LARGE jar of skin thickener.
    Then....... post away!
    In the meantime, you can spend some time searching on here for solid axle front ends and steering gears. There's a lot to be learned from all these guys, and as long as you use the skin thickener as suggested, you'll get a lot of good advice and guidance.
    Good luck!
    Just Gary and 51504bat like this.
  17. brokenspoke
    brokenspoke
    Hair pins should only be used on Tube axles
  18. nobby
    nobby
    The way to tell it's Econoline is the top of the king pin which has a bulbous shape to it, note the king pin incline of that spindle will be of a different one to an early ford. So you may not be able to switch them onto a stock or aftermarket early axle. What you gain is a wide shoe and self adjusting
    brakes as stock. I am reckoning it's due to a 14 inch wheel, but am not 100 certain
  19. jeff.l.hecht
    jeff.l.hecht
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    you are incorrect. the cut off is not 64 it is 65. here is a quote from the rules. so yes, 65 Impalas are ok....
    4. We cover traditional '65 and older American cars only.
    Rickybop, 51504bat and 57 Fargo like this.
  21. metalhead140
    metalhead140
    That rack arrangement is... different! No bump steer with a rack mounted to a solid axle. But you'd have to have a slip joint with lots of movement and a couple of wide range unis in the linkage back to the steering wheel, to allow for suspension motion! Can't see how it would possibly have ever worked properly as is, unless the mounts allow the entire steering rack to rotate?!
  22. seb fontana
    seb fontana
    from ct
    Pre '66.
    Moriarity likes this.
  23. Dave G in Gansevoort
    from Upstate NY
    So just being a newbie relatively speaking, would a rack and pinion from a 1959 Mini be verboten? It's age is appropriate...
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    rack and pinion is off topic......
  25. ottersea
    ottersea
    Well that leaves me out as I have on in my 56
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    not a problem simply do not post pics of your steering or discuss it....
  27. Illustrious Hector
    Illustrious Hector
    Tube axles should NOT be used with split wishbones.
  28. blue 49
    blue 49
    from Iowa
    ^^^^Hairpins locate the axle in the same way as split wishbones. I've always read that tube axles need four bars.
    Gary
