Anyone have any EZ way to move my seat back about 6" I am 6, 1 and I need some more room. The car is mint and I am not interested in chopping and cutting and drilling if possible. Nothing permanent at this time. Thank you for the help.
I understand not wanting to chop or cut but the only easy way is to drill four holes in the floor and move the seats back. HRP
Just make 2 new offset front mounting brackets/ pegs for the seat Sometimes you can just turn the mounting pegs around and will move the seat back about 3" later kb
I made new seat mount clevises that come up thru the floor in the original location, but I moved the hole location reward and added a few extra holes for different height of drivers. I will try to get out to the shop and take a picture if you want.
As said before, you may simply be able to flip/spin the mounts and gain 3", or make yourself a set of mounts that are offset by what you really need (I'm 6'6", and have the same issue with ANY 20's car smaller than a Packard ). Looking forward to seeing your solution!
I put a steel plate where the wood was under the seat and drilled holes in it for the new seat location. Worked pretty good. Posted using the Full Custom H.A.M.B. App!
