Technical Help me put a T5 in my 1950 Pontiac.
Discussion in 'The Hokey Ass Message Board' started by Jay Tyrrell, May 31, 2014.
  1. Jay Tyrrell
    Jay Tyrrell
    Will the 1994 engines crankshaft holes in the back of the crank line up with the holes in the flywheel that was made between 1987 and 1992?
    Jay
  2. gimpyshotrods
    gimpyshotrods
    The crank seal switch was in 1987.
    55gasserkid likes this.
  3. gimpyshotrods
    gimpyshotrods
    I believe that it will bolt up, but am not sure if everything else is equal. I will check when I get home.
  4. Jay Tyrrell
    Jay Tyrrell
    Cool man! Much appreciated! I will check my messages in the morning. Time for sleep tonight. 10:30 pm here! lolol
    Jay
  5. gimpyshotrods
    gimpyshotrods
  6. gimpyshotrods
    gimpyshotrods
    The 1994 flywheel should work, but will not accept the 10-1/2" clutch.
    That year had an 11" clutch.
    Have you thought about how you are going to actuate this clutch?
  7. Jay Tyrrell
    Jay Tyrrell
    I was going to use the hydraulic system out of an S10 that I have sitting here.
  8. Jay Tyrrell
    Jay Tyrrell
    Now when you are saying the 1994 flywheel will fit you don't mean the 1994 flywheel that I already have do you? I looked at the application for that summit clutch that you forwarded me and it said that it would accept a 10.4 clutch? hmmm? Take a look.
    http://www.summitracing.com/int/parts/zzz-50-6527/applications/year/1990
  9. gimpyshotrods
    gimpyshotrods
    Aftermarket flywheels often have multiple pressure plate patterns drilled in them. Factory ones do not.
  10. gimpyshotrods
    gimpyshotrods
    Also, count the teeth on that 1994 flywheel.
  11. Jay Tyrrell
    Jay Tyrrell
  12. gimpyshotrods
    gimpyshotrods
    The seal change was in late '86. I just say '87, to make sure.
    There cannot be one flywheel that fits 1985-1992.
    E88128 does not show the counterweight that is present on one-piece seal flywheels.
    F88130 shows the weight.
    The one-piece seal engines are externally balanced, by that counterweight that you see above.
    All of this is NOT TO BE CONFUSED with NCF88282.
    Which is a flywheel for a T56 pull clutch. Not the similar look to the T5 flywheel , but the totally different thickness. Shown below, T56 above T5.
    Get: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Flywheel/_/R-NCF88130_0317634779
  13. Window Licker
    Window Licker
    1986 was the change over
  14. gimpyshotrods
    gimpyshotrods
    Well, mostly. From service work in that period, I can say that GM was not too clean in the changeover.
    It often feels like they found an engine block/crank/short-block in a back room, or on a shelf, that they missed, and decided to toss it in.
    I have seen several 1986 Camaros and Firebirds, with their original engine, that had two-piece seal cranks/blocks, both manual and automatic.
    This is why I always say 1987-1992. Cuts down on the angry internet tough-guys.
  15. Jay Tyrrell
    Jay Tyrrell
    Now this is making sense. Man great resource and info here! Thanks for the link too. I am going to check on a price here in Canada and see where I am at there. They do look similar but are definitely different went you see both of them together. Jay
  16. Jay Tyrrell
    Jay Tyrrell
  17. Jay Tyrrell
    Jay Tyrrell
    I can't believe how those two flywheels look so similar! Half an inch would make a difference if I had used it... lolololol
    Jay
  18. gimpyshotrods
    gimpyshotrods
    Yup. Not sure that you would be able to get the bellhousing on over the pressure plate, or get the clutch to release, if you did.
  19. Jay Tyrrell
    Jay Tyrrell
    So I know that there are a variation of clutches and pressure plates man. Where should I start wHen sourcing my clutch and pressure plate?
    Jay
  20. Window Licker
    Window Licker
    I used all astro van parts when i did mine, but i used an 11" clutch disc.
    may have to cruise threw rockauto.com for a while till you find a 10.5" disc with the right spline count.
    maybe this (AMS AUTOMOTIVE Part # 04054): Flywheel Spec: FLAT; Use Kit (04-054) when converting a 4 or 6 cylinder engine to a small block V-8 using the OE 1" x 14 spline transmission.
  21. Jay Tyrrell
    Jay Tyrrell
    Well Gimpyshotrod just wanted to thanks you again! Got the flywheel you recommended and a 1987 clutch and pressure plate for a camaro and put it all together today and it works mint! Jay
  22. gimpyshotrods
    gimpyshotrods
    Always happy to help!
