Technical Help mitigate 2 Holley 94's/a stock 50 flathead
Discussion in 'The Hokey Ass Message Board' started by jamesd1502, Dec 17, 2015.
  1. jamesd1502
    jamesd1502
    from san diego
    Having a heck of a time trying to dial this engine in. Running 2 Holley 94's/edelbrock intake(not super)and tried multiple combinations of jets and power valves. Starts up fine and idles well but when I get it on the road it pops from time to time. I see or feel any vacuum leaks. Spark plugs were on the whiter side but having increase jet size, they are i.e. Blksh?? Any suggestions fellas ???? ImageUploadedByH.A.M.B.1450381440.629840.jpg
  2. I wish I could help you here. My only suggestion is to take a can of WD-40 or starting fluid and look for a leak.
    remember that you are no doubt running gasohol and the plugs are not going to read the same as with pure gasoline.
    hipster likes this.
  3. Bruce Lancaster
    Bruce Lancaster
    First, what Model carbs (marked on left side of bowls) and what size of jets have you been working with?
  4. Timbofor
    Timbofor
    If it randomly and occasionally pops while at a steady cruise I'd be looking at my ignition system. Advance weights hanging up maybe? What type ignition are you running?
  5. Bruce Lancaster
    Bruce Lancaster
    Looks like a real Mallory, two piece cap.
  6. jamesd1502
    jamesd1502
    from san diego
    Bruce, I'm away from the vehicle at the moment but from I recall one of the 94's has a ford marking and the other 94 does not have a marking
  7. jamesd1502
    jamesd1502
    from san diego
    As far as ignition, I'm running a vintage dual point Mallory dizzy (good points and condenser). 6 Volt system
  8. 38 Ford Guy
    38 Ford Guy
    I have 51 jets, 1.5 power valve in back carb 3.5 in front carb. Also, how did you sync carbs. I abc both carbs idle stops all way off hold both fully shut and tighten linkage to throttle shafts. Then equally adjust idle stops to they open equally enough to idle. Works every time for me.
  9. jamesd1502
    jamesd1502
    from san diego
    I'll try that power valve and jet combo and see how it goes. I used a basic carb synchronizer. I'm trying to vision your method of synchronizing the carbs. ???
