Help! My engine just developed ticking/ knocking!
Discussion in 'Traditional Hot Rods' started by Devin, Jun 9, 2014.
  1. Devin
    Devin
    from Napa, CA
    Gotcha. To bleed off the pressure. So to be correct I need to tighten the poky lock to take out all lash? It's a solid lifter cam, will that still work?
  2. saltflats
    saltflats
    from Missouri
    Yes it will work just dont get carried away and have the piston bump a valve.
  3. Commish
    Commish
    from NW Ok
    Try unplugging number 8 wire first, many times the knock will almost disappear if it is a rod.
  4. Remember :
    If the noise is about the same frequency as the timing light, that puts you into a cam speed related issue. Noise 2x the frequency of the light puts you into a crank speed related issue.
  5. ClayMart
    ClayMart
    Like this procedure as opposed to just killing the spark! That's a new one on me. Wonder if that might help isolate a wrist pin noise as well.... :D
  6. Bean Dip
    Bean Dip
    Sorry if this has been covered all ready but I'm in a rush this morning and wanted to help if I could. An exabust manifold leak can also make a "ticking" noise. May just make sure your header bolts have not got loose. Happens a lot.
  7. Im Trying to see the advantage of over adjusting a valve vs just removing the plug.
  8. sunbeam
    sunbeam
    May be that nut that was laying in the intake made it into the cylinder it's happened before.
  9. Devin
    Devin
    from Napa, CA
    I tried that and the noise persists
  10. Devin
    Devin
    from Napa, CA
    I think the noise is too perfectly timed to whatever is happening mechanically. Until I open the engine up, it could be anything.
  11. Devin
    Devin
    from Napa, CA
    Is there anything related to the distributor drive gear, oil pump shaft or oil pump that could be doing this also?
  12. big duece
    big duece
    from kansas
    Might pull the dist, and look at the gears. Maybe try another just to rule it out. Valve spring cracked or broken?
  13. Devin
    Devin
    from Napa, CA
    I recently installed a new distributor and am now wondering if that had anything to do with it. Thanks
  14. Yes, there's a lot of things happening back in the vicinity of # 8cly, and that are cam speed related. I mentioned this in an earlier post.
  15. So did your noise start around the same time ?
  16. Devin
    Devin
    from Napa, CA
    Shortly after. I measured the cam gear clearance and had 0.030" and made sure the dist shaft was not bottomed out and without any movement when installed. There was not excessive clearance but still some up and down. About 0.025" as best I could measure. What should I look for around the pump area. Thanks all this is giving me some direction.
  17. fur biscuit
    fur biscuit
    should have thought of this earlier, but record the car running with your hamb app'd iPhone! want to hear the sounds...
  18. Atwater Mike
    Atwater Mike
    Turn the engine over by hand, and check the lift on #8 intake and exhaust valves; compare with valve lifts on a cyl toward the front.
    Methinks you have flattened a cam lobe. (specifically #8 exhaust)
    Hemi32: If you pull the plug and start the engine, the whole neighborhood will hear it. The noise is hellacious.
  19. Flat cam lobe or bad lifter would make that tappet and/or rocker noisy. As well as throw the compression off.
    You could do a cranking compression test as well as a dynamic (engine running) compression test.
  20. Devin
    Devin
    from Napa, CA
    Agreed. I don't know how to embed a video.
  21. rjgideon
    rjgideon
    If you record the video, then post it to YouTube and just paste the link here. I really hope it's something simple and the engine is ok.
  22. oldcars.acadia
    oldcars.acadia
    Pull the intake and check the lifters to make sure your not damaging crank and bearings with cam grindings. Couple hours and intake gaskets is cheap insurance. Did you break cam in with double valve springs in place? High valve spring pressure can wipe a cam during break in.
  23. Devin
    Devin
    from Napa, CA
    You and me both! I'll try to get a video this weekend.
  24. Devin
    Devin
    from Napa, CA
    I removed the inner springs for the break in process. I will pull intake this weekend. Thanks all
  25. saltflats
    saltflats
    from Missouri
    When you open a valve you do not have the comp stroke pushing on the piston it just free floats different than pulling the plug wire.
    And it could help on a wrist pin noise diagnosis
  26. 63bluenova
    63bluenova
    What kind of oil you using ?
    And are you using zink additive ?
  27. Devin
    Devin
    from Napa, CA
    Valvoline racing 10w30 with Lucas zinc additive.
  28. 63bluenova
    63bluenova
    The engine shop that built my 327 told me to use straight weight oil
    They told me to use rotella t1 30 with zinc
    How was cam broke in?
  29. Commish
    Commish
    from NW Ok
    Noise persists, as in no difference at all? If so, probably not rod or piston related.
  30. theHIGHLANDER
    theHIGHLANDER
    The timing light thing, if the noise is in sync with light on-light off it would be lower end. If it's light on only you're looking up top. I'd drop the old distributor back in and rule the new one out if it's still there. Anything you may have done from the time it appeared? Go back to your baseline and start over 1 at a time. The basics always win so, good luck with it and thanks for keeping the board in the loop. These topics help everyone reading them.
