HELP!! need a 4rth gear or different gears
Discussion in 'The Hokey Ass Message Board' started by THETOWMAN, Nov 10, 2012.
  1. THETOWMAN
    THETOWMAN
    Hello everyone..I got 65 dodge a100 three on the tree..on the freeway sound horrible..I think I need another gear.or different rear gears...any advice would be appreciated..thanks
  2. GassersGarage
    GassersGarage
    Depends on how much you want to spend. Changing rear gears would be the cheapest and easiest but gear selection might be limited for the stock rear end. Anything close to 3:23's may be a good all around gear.
  3. 49ratfink
    49ratfink
    maybe you just need a muffler.
  4. 38Chevy454
    38Chevy454
    Most 4 speed will have the same 1 to 1 gear ratio in high gear as your 3 speed. If you want an OD trans, it is a 5 speed you need. Or one of the 3 speed with OD 4th gear trans. A rearend swap is probably easier, I am guessing you have the 8.75 rearend? If so easy as swapping out the pumpkin, similar to Ford 9-inch.
  5. Dragsterbus
    Dragsterbus
    from England
    I put 275/60/15s (on 8 1/2 slots) on my '69 A108 and that helped loads
