help, need advise on cutting a frame
Discussion in 'The Hokey Ass Message Board' started by surfmobile, May 7, 2010.
  1. Hey everyone, I searched the treads but didn't find anything that could answer my question so here goes..I'm planning on adding a c-section from Gambino Customs on the back end of my 50 Chevy. The question I got is it better to use a sawzall with the proper blade, or an O/A torch to cut out old frame pieces the new section will replace? I already have a real nice sawzall so that would be my first choice if it's do-able, But I will go get an O/A set up if thats what needs to be done. (Plus I know a O/A torch has a ton of uses) I know a lot of cats will say use a plasma cutter but I don't have one, don't want to buy one for one time use (too much$$$), and prefer to do all the work on the car myself rather than pay someone to do it. Advice o' knowledgable ones..por favor.
  2. 55 dude
    55 dude
    damm dude back in the day a hacksaw worked great! your sawzall will do fine or if you have air a grinder with cut-off wheel is cool!
  3. Thanks broseph, a sawzall it will be! I imagined that would be fine but just wanted to double check before I started ******* into the wind. Thanks again!
  4. PhilJohnson
    PhilJohnson
    4 inch cut-off wheel on an electric grinder and steady hand is all you need. A cutting torch is too sloppy and SawsAlls usually don't cut all that straight (or maybe my sawsall skills may be lacking).
  5. DonnyB
    DonnyB
    from Indiana
    A Metabo with a 6" cut off wheel works great and super clean cuts
