Technical Help Needed... knuckle support
Discussion in 'The Hokey Ass Message Board' started by 55oldsholiday, Oct 30, 2019.
  1. 55oldsholiday
    55oldsholiday
    Hey guys,
    So I was working on my 1955 oldsmobile today and the front suspension on the drivers side was very sloppy. Took it apart and discovered the knuckle support is stripped. Anybody know a fix for this or where I could locate a replacement? Did a general search and came up with nothing. Any help is much appreciated.
  2. 54vicky
    54vicky
    while this is a hot rod site not a resto site take it to a machine shop.have them sleeve it
  3. Texas Webb
    Texas Webb
    Good info,but this is the HAMB and its about helping others out.
    VANDENPLAS likes this.
  4. actually, this site has become all about restoring. we go ******* over old hotrods somebody's restored, and start whining when said hotrods are hotrodded instead of being restored. it's a 55 olds, fits the year cutoff, and OP asked nicely with pictures. I do agree with the sleeve idea tho.
  5. Boneyard51
    Boneyard51
    Look closely at the bottom hole, I ***ume that’s the one stripped, as the threads in the top hole look good. As with all raw castings they are held in a jig for machining and there are variances. This one was machined a little to the right. See how thin the right side of the hole is substantially thinner than the left side. Any machining in that area for a “ sleeve” might compromise the strength of the casting.
    A new part gets my vote.
    Bones
  6. BJR
    BJR
    I would try to adapt a ball joint suspension from a newer GM car. It all unbolts, use the a frames and all the rest of it.
    Boneyard51 likes this.
  7. 55oldsholiday
    55oldsholiday
  8. 24riverview
    24riverview
    Hard to tell without a better picture but want to be sure you realize the "threads" in the lower pivot aren't very deep to begin with. I would think the only way they could be damaged is if the bushing was froze on the shaft (it's supposed to pivot on) and turned in the upright or if they were damaged when the bushing was removed. Picture (from Fusick website) shows a new bushing ***embly and you can see what the outer threads on the bushing look like.
    http://www.fusickautomotiveproducts.com/prodinfo.asp?number=K50
    Hnstray likes this.
  9. bschwoeble
    bschwoeble
    Look for a good used one on e bay.
  10. vtwhead
    vtwhead
  11. Boneyard51
    Boneyard51
    Just for giggles I went over to E BAY and found one in about thirty seconds. Didn’t price it , but it’s there.
    Bones
  12. F-ONE
    F-ONE
    from Alabama
    He may be running a hot J-2 and 4 speed Hydro. IMHO.... it’s a legit question.
    You did give a good repair suggestion.
  13. 55oldsholiday
    55oldsholiday
    So the bolt on top is from the stripped pivot and the bottom is from the other side. I was able to locate one in Texas. Thanks to everyone for the advice and suggestions. IMG_6563.JPG
    Boneyard51 and 302GMC like this.
  14. inthweedz
    inthweedz
    Is the hole in the knuckle worn / ovalised??
    The trunion bushes never had a heavy thread profile from new, they usually nip / tighten up in the knuckle, and the pivoting movement is taken on the thread of the long bolt..
    A trunion bush kit should fix the problem..
